Movit brake calipers
Right Whilst at AmD yesterday having new pads it was pointed out that i have split calipers where as John Roberts has one piece calipers
So why the differece and which one is better or worse
I note the standard porshe pads do not fit my calpiers and i have to have Brembo pads
Really confused [img]images/graemlins/confused.gif[/img] [img]images/graemlins/confused.gif[/img]
Can't beat a bit of boost!
Re: Movit brake calipers
but Brembo is Porsche [img]images/graemlins/confused.gif[/img]
Andiroo
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
The Movits are Monobloc (one-piece), as are the Sportec & Porsche. The Brembo's I've got (now Thorney's [img]images/graemlins/wink.gif[/img]) are also Monobloc, and pads that fit the Sportec, fit the Brembos and JR's Movit's (sorted his pads at Anglessey).
Which calipers have u got mate [img]images/graemlins/confused.gif[/img]
Andiroo
Andiroo
- johneroberts
Andiroo
Friday afternoon specials by the sound of things... Bushy did Scott sat thet were GT2 system ?
Sounds like there off the 996T.
jr
Driving is believing
RS246 Founder
apparently the two piece caliper is marginally improved as it has two different size pistons, leading and trailing, and generates less heat?
Dont ask me
However I am looking into pads as only the brembo pads fit but AmD stock teh Porshe ones you had fitted John and they wont fit????
Looks like, side by side the brembo has a llarger friction pad, but not 100% sure
I have emailed Jas traction so let you know the reply
Dont ask me
i got this reply from S3Paul
awaiting jas tractions answer
1, stronger. a two piece caliper naturally will want to pull apart under brake force.. with the braking force trying to spread the caliper apart on the join.... hence the big cross bolts holding it together.
2. Lighter, reduced unsprung weigh (makes suspension more responsive) , as there are no big (heavy)crossbolts holding the caliper together...
Nordschleife
Guys
Mov'it uses the Brembo callipers fitted to both the 993 Porsche Turbo and the Porsche 996 Turbo. Both of these are 4 piston callipers. In the latter case these are monobloc, ie a single casting. There are both advantages and disadvantages to monobloc callipers.
Single castings are lighter, cheaper to manufacture and have less to go wrong. However, there are potential problems, nobody can predict the internal resolution of forces in a complex single casting, so potentially it may fail through internal stresses introduced during the casting process.
Whether the monobloc can apply greater clamping force is dependent on the design, it is not inherent to the structure of the calliper.
If you look at a number of Brembo race callipers, you will see that they are not of monobloc construction. The engineer who was showing this to me preferred it to a monobloc calliper because each component part was engineered from a simple casting in which there would be no unresolved internal stresses caused by the casting process.
Anybody really interested in brake design for high performance street cars should study the new callipers and rotors now available from Mov'it, these incorporate the state of the art thinking on this topic. Mov'it has learnt that you cannot just take race technology and apply it to street cars, race cars get a brake rebuild after every race, for instance.
HTH
R+C
HTH
R+C
Good point, heavier - but better by design.
I take it Mov'it are using seperate castings for this new line Robin?
Bushy, are the pads you are using the same shape as ours but with what seems to be a balancer pad at the top and bottom ?
Andiroo
Andiroo
the metal backing piece is a larger shape, yours has a curve/arc cut out of one edge, whereas mine seem to be straight edged
the pad material looks bigger
so not really sure
going to order another set and tehn take a photo to compare
so not really sure
Like these mate?
Andiroo
Andiroo
no
you see the RH side is parallel to the LH sid eon mine, and your dont fit
[img]images/graemlins/frown.gif[/img]
mine dont have the groove down the centre either?
Sorry mate, those aren't my pads - just trying to figure out what pad shape you've got.
Those pads are from these calipers - spooky
Andiroo
Andiroo
Users browsing this forum: No registered users and 22 guests
