Black soot !!!
2.2 I5 20v turbo - 315 bhp
tom1
Black soot !!!
Post by tom1 » Fri May 23, 2008 7:32 am
This is probably a stupid question, but i have started to get some black soot type deposits on the back of my bumper from the exhaust, is it a sign of running too rich or could it be something else?
Tom
dummi
RE: Black soot !!!
Post by dummi » Fri May 23, 2008 8:19 am
is your CAT ok?
alastairg
RE: Black soot !!!
Post by alastairg » Fri May 23, 2008 11:55 am
I have always had this. When Mihnea custom remapped my car we had a long chat and the OEM map runs very rich to allow for poor fuel that some owners would have used. However any boost leak will cause richer running. I recently changed the MAF to TURBO air hose with an increase of 5mpg !!!! As thats all I changed I suspect I have run with a small boost leak for a long time. Big boost leaks cause significant performance drops & black smoke as the ECU cannot adapt to them. Small ones I suspect the car copes with & chucks in extra fuel.
tom1
Post by tom1 » Fri May 23, 2008 3:03 pm
How would i know if the cat has gone?
According to the trip i average around 18-19 mpg around town which is what i manily do, and around 24mpg on a run. There doesnt seem to be any loss of power to (still pulls like <beep>:))
Lloyd
Post by Lloyd » Fri May 23, 2008 3:17 pm
As A said above. Soot means over fuelling, it's basically un-burnt fuel exiting the pipe. Look for an air leak. Perhaps change Lambda probe for a new one?
Can't see how it may be the cat's although happy to be corrected.
Lloyd
RS2+
tom1
Post by tom1 » Fri May 23, 2008 3:18 pm
Looks like i should maybe check for leaks then.:)
dummi
RE: Black soot !!!
Post by dummi » Fri May 23, 2008 5:45 pm
don't worry I had been reading about CAT function earlier today, still at the front of my mind, it is more likely over fueling, especially since you still have power
alastairg
RE: Black soot !!!
Post by alastairg » Fri May 23, 2008 7:04 pm
RS2 cats are wire mesh. IMHO they do not fail like ceramic cats
AlWyn
Post by AlWyn » Fri May 23, 2008 10:36 pm
Tom give me a call if you want to try my `spare` probe :wink: CheeRS Al
tom1
Post by tom1 » Sat May 24, 2008 12:38 am
I might do that Al...thanks:)
alastairg
Post by alastairg » Sat May 24, 2008 9:39 am
I suggest you get the car checked for fault codes which may point you in the right direction
tom1
Post by tom1 » Sat May 24, 2008 12:12 pm
I think what i will do first is fill up with v-power as the last few fuel top ups have been with esso 97 as the shell garage is a bit of a distance and i have been lazy:(
