German on phone dial and answer
ChuckUK
Post by ChuckUK » Thu May 22, 2008 7:21 pm
Hi guys,
I still haven't had much luck programming the correct language into the bluetooth module with VAGCom.
I have selected module 77 and notice the soft code ends in 22, this states english for display.
Any ideas why the multifunction display in between the revs/speedo shows german?
PetrolDave
RE: German on phone dial and answer
Post by PetrolDave » Fri May 23, 2008 10:22 am
What is the coding you currently have at address 77?
ChuckUK
Post by ChuckUK » Fri May 23, 2008 6:10 pm
Currently on 0010722.
PetrolDave
Post by PetrolDave » Fri May 23, 2008 6:51 pm
That's weird because that's the same coding as I have and mine is in English!
Does the DIS show German only when it displays phone information or at other times as well?
ChuckUK
Post by ChuckUK » Fri May 23, 2008 7:18 pm
Only phone information, Bluetooth connect or disconnect and make or answer a call.
PetrolDave
Post by PetrolDave » Sun May 25, 2008 6:47 pm
I'm out of ideas - 10722 is definitely the correct coding.
One last question - what's the part number of your Bluetooth module , especially the suffix letter? It should be something like 8P0 862 335 x - you can read it easily with VAG-COM.
ChuckUK
Post by ChuckUK » Sun May 25, 2008 7:54 pm
I'll check that out once the rain stops :)
ChuckUK
Post by ChuckUK » Sun May 25, 2008 8:17 pm
Users browsing this forum: Google Adsense [Bot] and 187 guests
