600hp+ kits
2.7 V6 30v biturbo - 380 bhp
DerekS
600hp+ kits
Post by DerekS » Wed May 21, 2008 3:24 am
Hi all,
New member here in Australia.
I am looking for any feedback on either the Dahlback or MTM 600hp+ kits for the B5RS4.
I have used the search function but no results.
Or if anyone has any other recommendations for this kind of power level let me know.
Derek
andream88
RE: 600hp+ kits
Post by andream88 » Wed May 21, 2008 8:11 am
This is the future:
http://www.audizine.com/forum/showthread.php?t=210859
And it costs 1/3.
This is the result of a similar kit, on a BONE STOCK Audi S4 b5. So only turbos, downpipes, and ecu upgrade. Nothing else.
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
okkim
RE: 600hp+ kits
Post by okkim » Wed May 21, 2008 10:51 am
I would like to see those bone stock S4 blocks with that kind of power. I am quite sure that those rods won't last long.
dummi
RE: 600hp+ kits
Post by dummi » Wed May 21, 2008 11:46 am
beautiful work he did
andream88
RE: 600hp+ kits
Post by andream88 » Wed May 21, 2008 5:22 pm
Rs4 b5 06/2001
JonnyX
Re: RE: 600hp+ kits
Post by JonnyX » Thu May 22, 2008 9:43 am
okkim wrote:I would like to see those bone stock S4 blocks with that kind of power. I am quite sure that those rods won't last long.
Depends on the torque and where they are putting the limiter. I agree though, I wouldn't
touch this without rods, caps and probably an RS4 crank. Interesting that they seem to be
implying the heads aren't a restriction (which I find difficult to believe).
The stuff looks really, really nice though - particularly the EMs.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
jc..
RE: Re: RE: 600hp+ kits
Post by jc.. » Thu May 22, 2008 12:45 pm
thought the main difference between S4 and Rs4 engines was the crank and teh cosworth engineered head?
S2tuner
Trader (Expired)
Post by S2tuner » Thu May 22, 2008 2:30 pm
The list of differences between S4 and RS4 engines is longer than the list of parts they share. hope that sums it up. Oh and I'd love to see real 600 HP at the crank that can take a few Vmax runs on a stock S4 block and heads. :lol:
DerekS
Post by DerekS » Fri May 23, 2008 12:00 am
Thanks for all the suggestions lads.
However I am starting with an RS4 not an S4.
I have been in touch with MTM and they need the car there to do it. So thats not an option.
Dahlback are the same.
I can do the Oettinger kit for 520hp bolt on and no internals, drive away and reliable.
What I am looking for is someone who has done 600hp+ and info on what they used. This customer wants 600+hp.
I am an Oettinger and APR dealer here in Sydney so I am capable of doing what ever it takes but I don't want it to be experimental as the customer lives a few hundred km's away.
I appreciate all your help.
Derek
andream88
Post by andream88 » Fri May 23, 2008 9:55 am
Are you able to do ECU custom-tunes?
Rs4 b5 06/2001
DerekS
Post by DerekS » Fri May 23, 2008 10:07 am
If need be I can get custom tune locally. I don't do them myself.
Its more a hardware kit that is going to be reliable and "unbreakable" that I am after. The less internals I have to the better also. Are the heads, crank, rods, bolts and pistons good to go to 600hp? Am I looking for something that doesn't exist?
andream88
Post by andream88 » Fri May 23, 2008 12:14 pm
IMHO, the best choiche for 600+ hp should be the kit i showed you (http://www.audizine.com/forum/showthread.php?t=210859).
Plus rods (1000-1200 $) and new pistons rings.
A Garrett turbo setup is MUCH MUCH more reliable than a KKK setup, due to decreased boost pressures.
For ex:
To make 450hp with a K04 setup you need 25psi of boost.
To make the same hp with a Garret setup you need only 15-17 psi of boost!!
If i were you, i'd choose the GT2860-7 Garrett turbo. It is capable of 310hp, and of 31lbs of boost!!
Bye
Rs4 b5 06/2001
dummi
Post by dummi » Fri May 23, 2008 2:05 pm
andream88 wrote:IMHO, the best choiche for 600+ hp should be the kit i showed you (http://www.audizine.com/forum/showthread.php?t=210859).
For ex:
Bye
he is a car tuner he must know all about flow rates and pressures...
andream88
Post by andream88 » Fri May 23, 2008 4:02 pm
Oh, ok! Sorry ;)
Rs4 b5 06/2001
don
Post by don » Sat May 24, 2008 7:39 am
Hi Derek, sounds like a crazy project, but look forward to any updates and seeing the finished project down at your workshop.
good luck :D
Users browsing this forum: No registered users and 89 guests
