Easy question, Hopefully!!
biggingermuff
Anyone know how to access the rear light cluster. One of my bulbs has gone...................Thanks
- Virdee Autos
- Trader (Expired)
RE: Easy question, Hopefully!!
Hopefully its the RHS, which you can do by opening the panel in the boot, the one with the slide down handle, where the warning triangle is usually
The other side the same principle, but last time I looked on mine, it was very tight, and I think you would have to remove the CD changer bracket to gain access/remove bulbs
Virdee Autos ~ 07950-526592
biggingermuff
- Virdee Autos
- Trader (Expired)
Well just open the panel where the CD changer is located, and you'll see the bulb holder through there.
Whether you'll be able to change the bulb with the bracket in situ is another Q!
