CEL...misfire.
2.7 V6 30v biturbo - 380 bhp
>RS4<
CEL...misfire.
Post by >RS4< » Mon May 12, 2008 11:35 am
Need some help here guys.
For two weeks my RS4 has a CEL coming up,we've had a vag-com connected to it and it detects a misfire on cylinder no:4
I have changed the spark plug and fitted a new coilpack but the problem is still there.
I can hear the engine not running normal (very slight judder) when it's stationairy but when i drive with over 2000 RPM's it appears to run normal.
Are there any other part that I can check ? Maybe injector??(don't think an injector can cause a misfire but i don't know)
I really don't want the stealers to dig into this,keeping my car for XX weeks...and presenting me the bill for not knowing what they've done... :roll:
Thanks :beerchug:
An opinion is like an asshole,everybody has got one.
SimonC
RE: CEL...misfire.
Post by SimonC » Mon May 12, 2008 11:51 am
Could it be this? http://www.rs246.com/index.php?name=PNp ... t=cam+wear
What was the spark plug like? Did you compare it to the others?
Are you sure you identified cylinder 4 correctly (no offence intended)? Remove all six plugs for comparison. Have you considered a compression test?
>RS4<
Post by >RS4< » Mon May 12, 2008 5:49 pm
Hello Simon, no offence taken offcourse.
Spark plug was normal (light brown colour)
Yes i'm sure it is cylinder no:4 as the vag com detected it as misfire on cyilinder no:4 which is if you're standing in front of the car right cylinderbank first one on the fenderside.
I'm not keen on repairing the camshaft thingy TBH..... :(
How can I be sure what it is?
Nige_RS4
Post by Nige_RS4 » Mon May 12, 2008 7:19 pm
It might be an EGT probe on it's way out too. Does it only happen at WOT or all the time?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Mon May 12, 2008 7:25 pm
Yep do a compression test first of all 6 cylinders, then take it from there.
Virdee Autos ~ 07950-526592
R5YUG
Post by R5YUG » Mon May 12, 2008 8:56 pm
If you've changed plugs and coil (try swapping one of the other coils to see if the problem follows the lead) - Not sure of the exact firing order but it should be firing in banks of two. Failing the all important compression test, a remote possibillity could be a blocked injector.
I've had a similar problem on a VR6 - at idle there wasn't enough pressure in the rail to get fuel into the dodgy nozzle / injector - worth a sniff anyway - but simplier to check the compression before fuel rail and injectors :-)
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
>RS4<
Post by >RS4< » Mon May 12, 2008 9:01 pm
Hmm i just had some new bigger injectors fitted for my new set-up..
Maybe this is causing the misfire??
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Mon May 12, 2008 9:27 pm
yep you could check that first!
R5YUG
Post by R5YUG » Mon May 12, 2008 9:32 pm
simple as = no or limited fuel = no fire / ;-) - You would see sooted plug - try some red-ex in your mixture
1968 Karmann Ghia
>RS4<
Post by >RS4< » Tue May 13, 2008 7:19 am
Will do guys! I'll keep you posted.
Any more info welcome!
>RS4<
Post by >RS4< » Tue May 13, 2008 7:26 am
Nige_RS4 wrote:It might be an EGT probe on it's way out too. Does it only happen at WOT or all the time?
Sorry Nige,didn't see your post,the cel is on all the time.
But it came on after doing 300+ km/h on the autobahn tho....
>RS4<
Post by >RS4< » Wed Jun 04, 2008 5:59 pm
Yep it's there......car has been to the stealers for a compression test and all cilinders are good exept no:4....
Stealers think there a crack in the cilinderhead,me too tbh.
And this when i've always been SO extremely carefull with it.
FU*K!!! :evil:
Nige_RS4
Post by Nige_RS4 » Wed Jun 04, 2008 6:34 pm
a) Is the car under warranty and b) do you trust your dealer? If the answer is no (or thereabouts), I would take it to a specialist for a second opinion and wouldn't let them change my airfilter, never mind take my engine to bits.
Just my 2p worth.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
rocketmq1
Post by rocketmq1 » Fri Feb 13, 2009 6:21 pm
RS4
What ever came of this? as it sounds very familiar to me at the moment! :(
A20LEE
Post by A20LEE » Fri Feb 13, 2009 6:55 pm
Nige_RS4 wrote:a) Is the car under warranty and b) do you trust your dealer? If the answer is no (or thereabouts), I would take it to a specialist for a second opinion and wouldn't let them change my airfilter, never mind take my engine to bits.
Just my 2p worth.
Specialist, dealers don't know what there doing.
