My wifes A4 2.5tdi has starter showing this fault so no air con....
High pressure sensor - open or short circuit...
anyone know where it is on the car?
Location of air con G65 high pressure sensor
tartan_rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
neckarsulm
RE: Location of air con G65 high pressure sensor
This was behind os headlamp on a 54 reg old shape A6 I fixed recently - you can see it on A6 but hard to get to unless lamp removed - good news is that it wont leak gas when removed.
Part was £35 and in stock so common - I think they called it a 'thrust sensor'.
It did fix the inoperative a/c
Good luck
Good luck
tartan_rob
Have got for for about £40 all in, location is to the right of the condensor behind the nearside headlamp.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Re: RE: Location of air con G65 high pressure sensor
im lookin for this on a a4 2003 b6 cab looked behind both head lights and cant see it do u have any pics etc or am i missing somethingTartan_Rob wrote:Have got for for about £40 all in, location is to the right of the condensor behind the nearside headlamp.
thanks
tartan_rob
RE: Re: RE: Location of air con G65 high pressure sensor
There is a cover I had to remove to be able to see it. I would show you but the wifes car in the garage for accident repair work and we are not expecting to see it back this side of mid October.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
