S4 Upgrading
Re: S4 Upgrading
Dippy,
I would think its turbo lag, as the acceleration is progressive and then you get the turbo whoosh. Probably down to the fact that i'm on full throttle after a change up.
I'll try the gradual increase of pedel pressure and see if the power comes in around the 3000-4000rpm range.
Thanks....Jem
Thanks....Jem
Re: S4 Upgrading
Jem
You need to pop round and have ago in mine......hide your Credir Card first : [img]images/graemlins/smirk.gif[/img] [img]images/graemlins/grin.gif[/img]
Re: S4 Upgrading
Hi Jeff,
I am avoiding popping rounds yours for a drive in the KO4's just for that reason...credit card. [img]images/graemlins/ban.gif[/img]
It will be just too tempting......
I'll be in touch soon.
Rgds
Rgds
Re: S4 Upgrading
Dippy,
Thanks....Jem
Also consider if you have DV problems: If you change gear they will open, and if they don't close quickly enough then you will get hesitation.
2001 Silver S4 Avant
Re: S4 Upgrading
What DV's do you recommend?
Re: S4 Upgrading
working ones..... [img]images/graemlins/smirk.gif[/img]
New Bosch standard ones will probable suffice.
Re: S4 Upgrading
Any with a solid piston. IMO the risk of diaphragm tear means the Bosch is out.
I think that the Forge, Hyperboost, Viper and Bailey valves are all good. Although I question if the Bailey and Hyperboost valves are a good fit or not: Space for the DVs on the biturbo is limited.
Re: S4 Upgrading
I know everyone has mentioned that they like the Porsche brakes. I presume that Porsche/Mov'it are one in the same. What size do people recommend? Is it 322x32mm?
Has anyone any views about the Stop-Tech brakes? Which size is best fitted? 332mm x 32mm or 355mm x 32mm? [img]images/graemlins/audiS4black.gif[/img]
RS 6+
2001-2006 S4
2006-2012 RS6
2012-2016 ML350 CDI
2016-2018 RS6 PE
2018 - Tesla MS100D
2001-2006 S4
2006-2012 RS6
2012-2016 ML350 CDI
2016-2018 RS6 PE
2018 - Tesla MS100D
Re: S4 Upgrading
Fantastic post guys & loads of info. I recently bought my S4 & as I live in Bicester got AMD to remap & shortshift the car. I have just bought an RS4 suspension kit plus a pair of Hybrid KO4 Turbos that have been gas flowed.
Anyone got any thoughts? Will the RS4 suspension be OK when the S4 is producing in excess of 425BHP???
Thank you all.
Thank you all.
'04 Audi A6 Saloon
Re: S4 Upgrading
The RS4 suspension will be fine unless you plan on attending lots of track days. I would also consider getting a stiffer rear anti-roll bar as you will experience understeer in fast corners. AFAIK, K04's on an S4 without the full RS4 treatment (injectors, airbox, MAF etc..) will only give you around 400-410bhp, as the std S4 injectors are maxed out [img]images/graemlins/crazy.gif[/img]. Did you get a quote from AMD to fit the turbos [img]images/graemlins/shocked.gif[/img] ??
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Re: S4 Upgrading
Hi Nige & yes, curremtly in negotiations with Jon & Scott down there. I live in Bicester which makes things easier (also makes spending money there easier too!!)
They are speccing out all the components I will need to do this - then they are going to hit me with the labour bill!! [img]images/graemlins/shocked.gif[/img] [img]images/graemlins/shocked.gif[/img]
'04 Audi A6 Saloon
Re: S4 Upgrading
Was it you I met at AmD yesterday? You seemed to be doing some intense haggling with Craig [img]images/graemlins/grin.gif[/img]
Btw your sig suggests torque of 409 ft/lbs, if that is correct you have more torque than a Sportec RS460 [img]images/graemlins/shocked.gif[/img]
Andiroo
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
Re: S4 Upgrading
Hi Andy & yes, we met yesterday! I have to say I am in awe of your car - AMD told me what that was pushing out! Next time you are down I would love to have a run out in it. [img]images/graemlins/bowdown.gif[/img]
I will check the RR printout, it was either 402 0r 409 but I was sure it was 409. I was surprised when I saw the report.
Im haggling with them on labour charges to install some Hybrid KO4s I have an option on!
How long have you had the RS4?
Was the Sportec kit put on straight away?
Sorry for all the questions, just thought the car was incredible!
'04 Audi A6 Saloon
Re: S4 Upgrading
Next time we meet, no probs mate [img]images/graemlins/wink.gif[/img]
I would check the printout carefully mate, to give you an idea Jeff's AmD RR figures show 326bhp/365ftlbs torque which is about right IMHO. You seem to have less bhp and bags more torque, just doesn't add up I'm afraid [img]images/graemlins/frown.gif[/img]
I will be posting up a history of Noggy Babe very soon for your perusal.
Andiroo
Andiroo
Re: S4 Upgrading
Hi Andy. I just dug out my RR printouts.
278BHP before - 323BHP after.
315lb before - 402lb after.
I need to amend my signature!!!
Does this really look odd? I have met a couple of people who have similar torque stats.
What is the Sportec 460 stats? (Maybe a dumb question?)
'04 Audi A6 Saloon
Users browsing this forum: No registered users and 175 guests
