facelift headlights in a pre-facelift car
RE: facelift headlights in a pre-facelift car
So am i correct in thinking that all i need to buy is the level motors for the facelift lights?
Wide Body S4
Possibly - £17 each ... euro car parts
happy dayz .... party ....
oooooooo sold. so how much of the wing do i need to cut away?
Wide Body S4
if you cut to the door you have gone too far...
Re: RE: facelift headlights in a pre-facelift car
Just the swaged part. Once you remove your pre-facelifts, you'll know the bit that has to be removed.h8cak wrote:oooooooo sold. so how much of the wing do i need to cut away?
It's the pressed section, not a lot. You can use a Dremel or similar. Just remember to use an appropriate rust preventer, and paint.
RE: Re: RE: facelift headlights in a pre-facelift car
All done. Bit of a work up but its done. Used the original hid set up from the pre facelift lights. Looks great and works a treat.
Wide Body S4
any pics as i'm looking to do this. my head light reflectors are dog <beep>
MRC TUNED 480BHP . -SOLD 1.9TDI AVANT 215HP. HYDBRID TURBO. SMOKING
Ill get some done tomorrow and post them up. Well worth doing IMHO
Wide Body S4
Looks miles better. Anyone got a set of facelift lights?
as above...
Ive got a spare pair of A4 facelift lights. Thats what i used. You will need to buy a H7 Xenon kit tho to replace the prefacelift xenon DS2 fitting bulbs. I was lucky with mine. I found an A4 that had Xenon lights so i just used my DS2 bulbs and ballasts.
Wide Body S4
you have pm
Think I might try and hold out for the option you took h8cak. Want to keep it all oem.
yes explain to them that you can do it with a non xenon unit, and just add a hd kit. ok its not leveling, but.... So you could pick up a cheap set of lamps and add the hid kit. looking back at old posts, some have said that aftermarket hd kits are a lot brighter than the oem. views?
Darren
Darren
Users browsing this forum: Google [Bot] and 46 guests
