Fault codes RNS E
mattykerby01
Fault codes RNS E
Post by mattykerby01 » Tue May 06, 2008 4:20 pm
Hi Guys,
When i brought my RS4 B5 the new RNS E system installed, but when i have tried to connect via VAG COM to change the screen display i cannot connect. I only find this fault code.
System works fine though?
Any ideas? :cry: :cry: :cry: :cry: :cry:
Address 17: Instruments
Control Module Part Number: 8D0 920 981 X
Component and/or Version: B5-KOMBIINSTR. VDO D13
Software Coding: 00462
Work Shop Code: WSC 00483
Additional Info: WUAZZZ8DZ1N902137 AUZ7Z0Y1621654
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
01304 - Radio
49-00 - No Communications
01311 - Information Data Bus
37-10 - Faulty - Intermittent
PetrolDave
RE: Fault codes RNS E
Post by PetrolDave » Tue May 06, 2008 6:40 pm
Sounds like the RNS-E installation has only been half done.
If you can't connect to the RNS-E (at address 37 or 56 it doesn't matter) then probably the K-line isn't connected.
If the instruments can't talk to the RNS-E then it sounds like maybe there is a CAN bus problem as well.
What "screen display" change do you want to make? You won't be able to make the RNS-E say "RS4" at startup - that only works if the RNS-E is coded for an A4 and in a B5 it has to be coded for an A6 to work!
mattykerby01
Post by mattykerby01 » Wed May 07, 2008 12:56 pm
Thanks Petroldave, but sorry to sound a bit dim but any suggestions who can look at this for me? i haven't a clue about the K-line connection or the the CAN bus
And yes i was hoping to display the RS4 logo on start up.
Matt
PetrolDave
Re: RE: Fault codes RNS E
Post by PetrolDave » Wed May 07, 2008 2:26 pm
mattykerby01 wrote:but any suggestions who can look at this for me?
Depends where you are based - I can take a look, I'm in Southampton.
mattykerby01 wrote:And yes i was hoping to display the RS4 logo on start up.
'Fraid that's just not possible on an RNS-E installed in a B5 RS4.
You have the choice - working RNS-E and normal startup screen, or non-working RNS-E (and possibly a flat battery) and the RS4 startup screen.
mattykerby01
RE: Re: RE: Fault codes RNS E
Post by mattykerby01 » Wed May 07, 2008 3:24 pm
Ok thanks for the help here, i think i will leave well along and opt for the working RNS-E.
Any ideas How much would it cost to enable the blue tooth ?
PetrolDave
Post by PetrolDave » Wed May 07, 2008 3:50 pm
It's not just a case of enabling Bluetooth - you've got to add the Bluetooth module and antenna, the microphone and a wiring adapter.
Total parts approx £450.
Return to “Electrical”
Users browsing this forum: Majestic-12 [Bot] and 62 guests
