cruise control fitting
I would like to fit cruise to my 98 s4. Is there any one out there fairly local to me in southampton / London who has fitted it and could give me a hand is i have not got a clue?
Wide Body S4
RE: cruise control fitting
Cheers. Very informative but still a little scared to do it on my own
Any kind offers?
Wide Body S4
Just get on with it. I found this very easy. I can send you some parts to make the loom as I was going to make a spare in case someone wanted one on the forum.
Carl I still got your address and will drop it in the post to you tomorrow morning if its any help.
call this guy..07971078619..his name is gareth..mention my name and see what he can do...
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Cheers si but i was looking at getting it done on the cheap as i have spent a small fortune on the car this month.....oop's
Wide Body S4
Re: RE: cruise control fitting
Do it yourself - it really isn't that difficult. It doesn't come any cheaper than that either.h8cak wrote:Cheers si but i was looking at getting it done on the cheap as i have spent a small fortune on the car this month.....oop's
RE: Re: RE: cruise control fitting
Dropped in the post - wires should be with you soon.
As dazzer said it really isn't that difficult.
Thinging about fitting cruise on my s4. So what other parts do you need?Stigter wrote:Just get on with it. I found this very easy. I can send you some parts to make the loom as I was going to make a spare in case someone wanted one on the forum.
And is there any coding in to be done?
All the parts are listed on the link above. Very good guide
Do i need to get an more wires? or is there enough?Dropped in the post - wires should be with you soon.
Wide Body S4
Re: RE: Re: RE: cruise control fitting
?Stigter wrote:All the parts are listed on the link above. Very good guide
looks ok. going to give it ago. Just one question. Connector T10ar is that at the back of the insturment panal cluster? If not what wires go there if any? THANKS.
Users browsing this forum: Google [Bot] and 89 guests
