Oil Light Coming On.
Hi Guys,
A little technical help required.
My oil light (Big red oil can) is occasionally coming on under hard accelaration - although I have the required amount of oil in the engine.
Any ideas why?
I do know that the book says 'Low oil pressure' but does this point to the oil pump or something else?
All comments greatfully recieved.
R.
Any ideas why?
R.
RS4 Misano Red (The Fast Colour) - A Few Extras = 550bhp - In Love Again - Now broken - Hate the Bitch... Has to go...
GT-R arriving 14/05/09 - Too many toys - not enough time...
RE: Oil Light Coming On.
Drive a bit slower perhaps Rich??
Re: RE: Oil Light Coming On.
No way - can'r do - car is flying.Peakz wrote:Drive a bit slower perhaps Rich??
- Virdee Autos
- Trader (Expired)
RE: Re: RE: Oil Light Coming On.
Weak oil pump or pick up...
Virdee Autos ~ 07950-526592
does the pick up pipe have a strainer on it? might be getting blocked maybe!
Big Andy W
- Virdee Autos
- Trader (Expired)
I'm not entirely sure, but going by previous VAG cars, I suspect it does.
As has been said maybe blocked
Thanks - the strainer should be clear - as I cleaned it not long ago - will test the pressure as well - but the car has done 90K so it could do with a new oil pump.
Thanks again,
R.
Thanks again,
R.
Just to keep everyone up to speed on this - it doesn't look like it's the oil pump.
Apparently the pump produces more pressure the more rev's the car does - it's normal for the pump / pressure warming to come on when it's very hot and at idle.
Have checked pressure - which is fine - so it could be oil starvation which point to a blockage or simular.
More to follow - sump coming off...
R.
R.
- Virdee Autos
- Trader (Expired)
IMO it's not normal for the oil pressure warning to come on at any time, apart from when "there" is a problem with that!
Even thought the pump produces more pressure, more the revs, bear in mind the oil will get thinner when warmed up.
It is the first sign of oil pump pressure being low. I have seen this on a few cars. no light on when you start. 5 minutes later when warm - do a a few runs, everything ok, then cruise but above 3k the light pops on. If you look at the pressure ok/not ok check then you can see it is not ok until you rev to about 3.5k.
I have also seen this on cars that have a cracked head and are starting to leak coolant into the bore and then leaks into the oil - the oil mixes and thickens up and then the pump cannot pressurise hte oil/water mix.
Don't ignore this warning as a duff sensor - and don't thrash the car until it is sorted - far to easy to spin a bearing or overheat a crank journal - then it is into big money to fix.
http://www.MRCtuning.com
- Virdee Autos
- Trader (Expired)
I have seen the same issue Doug has mentioned on the 1.8T engines aswell to do with weak oil pumps
Users browsing this forum: Google [Bot] and 31 guests
