RS4 spacers size
2.7 V6 30v biturbo - 380 bhp
Taipan
RS4 spacers size
Post by Taipan » Mon Sep 29, 2003 5:08 pm
Hi everyone,
Just a quick one to those who added spacers on their RS4 :
- did you put exactly the same size on front and rear, like 10 mm / 10 mm
- or did you put a higher figure on rear, like 10mm / 15mm ?
Cheers,
Eric
- RS4 V6 Biturbo Imola Yellow (2001)
• Custom MTM 460hp manually tuned by Peter Link on MTM dyno at Ingolstadt HQ.
• Custom Full Milltek: Sport-Cats / Mid-Silencer: suppressed / End-Silencer: reduced.
• Full Mov'It upgrade: Front 380mm - 6 pistons / Rear 220mm - 4 pistons / Parking addon.
- Joined the Dark Side (aka. Darth Elon) circa 2013.
Bushy
Re: RS4 spacers size
Post by Bushy » Mon Sep 29, 2003 5:31 pm
Th sportecs require 15/15
As do the BBS rims I was looking at
Can't beat a bit of boost!
LittleSkull
Post by LittleSkull » Tue Sep 30, 2003 9:26 am
Or else you can get the Tecnomagnesio Detroit F1+ and you don't need spacers [img]images/graemlins/1syellow1.gif[/img]
http://www.mimwheels.it/ita/schprod1_ne ... rticolo=71
http://www.mimwheels.it/ita/schprod1_ne ... rticolo=72
Bushy
Post by Bushy » Tue Sep 30, 2003 9:44 am
I think the standard 18" rims from Sportec do not need spacers, it is just the 19 x 10's that do, not totally sure
Also the Sportec rims are made by MIM for the record, they have the MIm stamp on the inside
JohnH
Post by JohnH » Tue Sep 30, 2003 10:19 am
My 18" Sportecs have spacers on them but not sure if that is because of the wheels or because I have the Movits on the front. Anyone know?
2004 X5 4.8is Le Mans Blue
Bushy
Post by Bushy » Tue Sep 30, 2003 10:22 am
Ok, must be the wheels
Cheapest way to make them I guess, do them as all 20mm offset then use spaceers to fita range of cars
The Movits should be the same hub position as standard, within about 5mm anyway
LittleSkull
Post by LittleSkull » Tue Sep 30, 2003 10:39 am
Sportec 18" have ET 35 so spacers needed. Why spend money on the Sportec wheels (which as Bushy said, MIM makes) when you can have the same design (1 spoke difference) and spend much less + no spacers????
Cheers,
Cris
TimJMS
Post by TimJMS » Tue Sep 30, 2003 11:25 am
15mm / 15mm for the RS6 19's on an RS4 Eric.
Taipan
Post by Taipan » Tue Sep 30, 2003 12:43 pm
OK so everyone kept the same size rear and front, thanks guys ! [img]images/graemlins/thumbs.gif[/img]
Eric
dog
Post by dog » Tue Sep 30, 2003 1:44 pm
I hadv12mm front and back with the BBS
Andiroo
Post by Andiroo » Wed Oct 01, 2003 12:26 pm
Just picked up on this thread sorry guys.
The Sportec 10x19's require a 20mm spacer as they are ET40 wheels, and 19x8.5 are ET35 like the RS6 and require 15mm spacers.
What you looking at Eric?
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
Taipan
Post by Taipan » Wed Oct 01, 2003 12:45 pm
Hi Andy,
I was just considering adding spacers around 10mm without changing the rims, for a larger width (for both road handling and cosmetic).
As I did it on the Passat and found out that the front wheels seem to be a bit out of the frame (but not the rear), I was just wondering about front vs rear.
Also some FR owners of S3 had +5 mm more on the rear than front.
Not sure if doing it different front/rear wouldn't be worse to handling than anything else.
Eric
