Why is my car making rubbish power??
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
dr_wimpkins
Post by dr_wimpkins » Sun Apr 20, 2008 9:47 pm
367 whp, 415 torque on the RR today.
For those of you dont know my set up is:
K04/06 hybrids
FMIC
Fuelling.
Remap.
Havent got the Thorney RR numbers to hand, but I think it was similar WHP but maybe 450 torque. At the time it had an ETG and overboost error code.
Today no error codes on the run, though I did get one since driving home.
did a quick log, boost seems okay to me, can anyone comment on any of it?
Getting my a$$ kicked by plain jane K04's, tempted to out the car in the bin at this rate.
All BLOW and no GO.........
dummi
RE: Why is my car making rubbish power??
Post by dummi » Sun Apr 20, 2008 9:53 pm
can I have 1st refusal before you put it in the compactor :))
RR's can be dodgy , there are too many variables and some of these guys I am guessing may be on k04's but have done a few other things to improve their results. be good to see all your graphs from the day
dr_wimpkins
Post by dr_wimpkins » Sun Apr 20, 2008 10:08 pm
Heres todays log:...
h8cak
Post by h8cak » Sun Apr 20, 2008 10:27 pm
It felt a lot more than that to me :)
Wide Body S4
dummi
Post by dummi » Sun Apr 20, 2008 11:25 pm
not seen k04 hybrid graph before but looking at it you could prob get some more power with a better exhaust or manifolds, seems it was held back after 5500rpm
quattronutter
Post by quattronutter » Sun Apr 20, 2008 11:29 pm
best to put up the complete engine spec to get a better idea,still using the s4 maf by the looks of things
dr_wimpkins
Post by dr_wimpkins » Mon Apr 21, 2008 9:10 am
Yeah sorry forgot to mention, Ive got ported and polished manifolds, and custom turbo back exhaust, no cats, approx 2.75" bore.
Fuel pump is bosch motorsport (mrc supplied)
Injectors 700cc (mrc supplied)
uprated clutch
Am still using S4 MAF, but have heard that doesnt affect power.
JonnyX
Post by JonnyX » Mon Apr 21, 2008 11:42 am
Do you have any FATs data. I find rolling roads useless TBH. How FAST is the car?
I have K04's(P&P ed), lowered compression, RS4 IC's and a load of other stuff and think my car is slow
(relative to others) as well. My best FATs is about 3.8 which I think is about .5 too slow for my mods.
I am slower than a lot of plain jane K04s as well. :-(
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
ZeroK66
Post by ZeroK66 » Mon Apr 21, 2008 12:04 pm
That torque curve looks way too flat. Sounds like the car may be choking and not breathing for whatever reason... exhaust maybe? Your torque curve should keep rising till about 5k.
Could be as simply as a bad tank of fuel causing timing to be held back.
Hybrid cars quite often seem to play up with power figures, that is why I avoided that route and stuck with the modded K04 route.
Biggest thing I think is the manifolds and exhaust... that is where you can see 60-80HP increase. Sad to say engine out and stupid money. Big thanks to Mihnea who spent 20 mins on the phone convincing me to get the manifolds.
Schlafer
Post by Schlafer » Mon Apr 21, 2008 12:53 pm
dr_wimpkins wrote:Yeah sorry forgot to mention, Ive got ported and polished manifolds, and custom turbo back exhaust, no cats, approx 2.75" bore.
Sorry guys if im being completed retarded here (having only just learnt what a spanner looks like!) But i was advised that the bore should be 3"? therefore docs bore being 2.75" ........ is this a consideration or are you all just rolling on the floor and laughing at what i just said?????
dummi
Post by dummi » Mon Apr 21, 2008 1:01 pm
2.75 off the turbo's is more than adequate to give good results
s4 maf is limited to what it can read, its limit will not be the limit of what the turbo's can flow. rs4 maf reads higher.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Mon Apr 21, 2008 1:38 pm
it is a single 2.75" - you could hear that restriction from outside - BUT - it runs good boost and maf and more importantly it is fast when you are in it or even trying to keep up with it - he pulled from me ont he way there.
http://www.MRCtuning.com
dr_wimpkins
Post by dr_wimpkins » Mon Apr 21, 2008 2:38 pm
aah yes but surely if it was making the numbers, it would be faster !!
Could well be the single bore at the back of the exhaust thats the issue, been planning to change that.
I need to check the WHP between the latest RR and Thorney last year, as nothing has changed on the car expect that there were no error codes on the run yesterday.
Has anyone who went to thorney compared the whp numbers (for those that didnt change the engine spec) Would be interesting to see how the 2 relate.
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Apr 21, 2008 3:10 pm
my car runs 3" downpipes for about 8 inches then into 2.5 inch pipes No cats. the exhaust in 2.5 duel to the first box then single 3 inch between that and the back box with one tail pipe
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Users browsing this forum: No registered users and 104 guests
