As above really. I thought that it was in the boot on the left hand side but before I go taking the trim off I just wanted to make sure.
Have you guys who have a Salon or Avant got an access flap to get to it or is it tucked away behind trim?
Any help much appreciated.
Graham
Position of TV tuner in RS4 Cab?
RE: Position of TV tuner in RS4 Cab?
Graham
In the saloon if the TV tuner is fitted it is located behind an access flap in the passenger side of the boot, if no TV tuner is fitted the boot trim is different and it only has a recess rather than the access flap.
if its any help i had both my trims off yesterday as i was putting in a base amp and a sub, the standard bose amp is located on the offside and i would of thought that the tv tuner would be there if there was one fitted from factory, but on the nearside there is a empty slot which looks like it would hold some sort of multimedia equipment, ps the nearside is easier to take out than the offside and its not an easy job you will have to take off the boot loading trim and the rubber before you can removal panels and then there is a grommit screw on the offside right above the luggage tray thingy what opens and closes with the handle.Love_iTT wrote:Mmm, thought as much. I'm sure the TV module is in the boot but there is no access flap so I guess it's going to have to be taking the left hand trim off to get to it.
Thanks for replying though.
Graham
- PetrolDave
The TV tuner is on the left hand side, hidden behind the panel in the lower section of the equipment rack.m5killer wrote:if its any help i had both my trims off yesterday as i was putting in a base amp and a sub, the standard bose amp is located on the offside and i would of thought that the tv tuner would be there if there was one fitted from factory
Users browsing this forum: Bing [Bot] and 305 guests
