MRC work and tuning advice needed
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
snadge
Re: RE: Re: RE: Re: RE: MRC work and tuning advice needed
Post by snadge » Sat Apr 12, 2008 10:01 am
Ads4 wrote:Have you mentioned injectors, fuel pump....
In my head yes, for the next stage but my clutch and bank balance dictates that I can't quite afford that yet...
Everything else that I need ie injectors, fuel pump, MRC custom remap etc, suspension and brakes will be done after I manage to raise the cash for parts, all this can be done with engine in situ.
I really wanted to do suspension and braking first but having a slippy clutch means the motor out work comes first.
snadge
Post by snadge » Sat Apr 12, 2008 10:33 am
jimbo1234567 wrote:ive got a rs4 oil cooler sat in the garage with no ones name on it.
is this fitted with engine in or out?
CliveH
RE: Re: RE: Re: RE: Re: RE: MRC work and tuning advice neede
Post by CliveH » Sat Apr 12, 2008 10:38 am
In.
Clive
snadge
Re: RE: Re: RE: Re: RE: Re: RE: MRC work and tuning advice n
Post by snadge » Sat Apr 12, 2008 11:04 am
CliveH wrote:In.
So although it is something that I want to add it can wait until later.
Will I need boost diverters at this point anyone?
dazzer
Post by dazzer » Sat Apr 12, 2008 11:15 am
snadge wrote:
CliveH wrote:In.
Do you mean DVs? Good old 710Ns will see you right.
Doug_S2
Trader (Expired)
RE: Re: RE: Re: RE: Re: RE: Re: RE: MRC work and tuning advi
Post by Doug_S2 » Sat Apr 12, 2008 7:26 pm
i think the awe crack where the autospeed ones crack
autospeed cracked manifolds.jpg (91.3 KiB) Viewed 816 times
http://www.MRCtuning.com
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat Apr 12, 2008 7:32 pm
the welds are only on top of the metal - you need to grind the welds off and weld them but get a good enough weld to melt the 2 metals together.
thick headgaskets are good if you want the most out of it. going to 450+ you should really have heads off to inspect the conditiopn of pistons/heads/valves etc.
If it is a really early S4 - you might have thin headgaskets - i have had one s4 heads off and the headgaskets look like normally aspirated thickness -so that car will be high compression andwill not run decent boost on ko4s.
dazzer
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: MRC work and tuning
Post by dazzer » Sun Apr 13, 2008 9:24 am
Doug_S2 wrote:the welds are only on top of the metal - you need to grind the welds off and weld them but get a good enough weld to melt the 2 metals together.
So you are saying that the cracked manifold scenario can be prevented or the chanced minimised by rewelding? I think I need to explore this before putting mine back together. So no amount of bracing of the turbos will help this situation?
dazzer
Post by dazzer » Sun Apr 13, 2008 9:49 am
Doug when you say 'good boost' what exactly is that in your book? And what CR will be determined with the gaskets you speak of. I want to eradicate as much lag as possible, get as close to 450HP and save having to take the engine out again. Yeah I know - don't want much!
Didn't MTM used to make cast manifolds? Were they any good, i.e. have the performance properties of tubular with better reliability.......
snadge
Post by snadge » Sun Apr 13, 2008 9:51 am
My S4 is 1999 facelift but with the earlier "C" ECU.
Hmm that welding doesn't look at all good to me, I will inspect mine fully and beef up if necessary.
The cracking will be due to vibration so bracing the turbos will help, rewelding will also help, when I do mine I will report back with solutions and piccies.
Doug, I think that when I arrange with yourselves for a book-in, to get the fuelling kit and remap done I will arrange for MRC to do the head gaskets, I would prefer yourselves to replace head gaskets than myself.
dazzer
Post by dazzer » Sun Apr 13, 2008 10:09 am
Pics of your solution will be very interesting, particularly if you can beef up the welding without doing anything that disrupts the flow internally.
Harper--D
Post by Harper--D » Sun Apr 13, 2008 2:35 pm
Takes along time to remove heads with engine in the car!
Dave.
White MK2 Golf.. Slightly modified :D
Peakz
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: MRC work and tun
Post by Peakz » Sun Apr 13, 2008 2:45 pm
Slightly off-topic but Dave I still keep laughing to myself about that chap switching on the ignition when Doug was working on the engine :shock: :biggrin2:
Ads4
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: MRC work and
Post by Ads4 » Sun Apr 13, 2008 2:51 pm
Peakz wrote:Slightly off-topic but Dave I still keep laughing to myself about that chap switching on the ignition when Doug was working on the engine :shock: :biggrin2:
More info please Paz....sounds like a good'un :lol:
Adam.
MRC B5 S4 Avant.
Peakz
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: MRC work
Post by Peakz » Sun Apr 13, 2008 3:18 pm
There was a really sound geezer having the spider hose replaced on his mint S4, Dougal was working on the car and this chap wanted to show me the benefits of the Phat Noise system. In his enthusiasm he switched on the ignition instead of just putting the key in, fortunately Doug was admiring his handy work but was a little perturbed to find the engine kick into life. . . . made me chuckle anyway :biggrin3:
Users browsing this forum: Majestic-12 [Bot] and 112 guests
