******Long awaited Gear Knobs and Braces for sale now******
espengineering
Post by espengineering » Thu Apr 10, 2008 7:30 pm
LADIES AND GENTS THE WAIT IS OVER!!!!
Starting from today we have a special introductory offer up to and including the RS246 live event on the 18th may!
Buy an ESP Engineering Gear box brace for our great introductory price of £160.00 (usual retail price £190.00) and you will be able to purchase a ESP Engineering Billet Gear Knob, with a standard engraving, for ,under half the retail price, £30.00!!!
Billet gear knobs are also available for the introductory offer of £45.00 (usual retail price £65.00) with a standard pattern engraved on them (this is RS4, S4, Audi Motorsport or 6 speed Audi gear stick pattern).
If you wish to have a PVD Ti (black) coated Gear knob this is an extra £12.00
It is not compulsory to have our engraving. We can engrave anything you wish (within reason). We are doing this at an introductory price of £20.00 per gear knob per custom engraving.
PLEASE NOTE DELIVERY will be £10.00 on all products. If you prefer to collect in person or just come and have a look at the products please feel free to come down.
Please e-mail me with your requests/questions to arrange orders/payment/shipment. Here is a little info on the products.
Product Info
ESP Engineering Gear Box Brace
The gearbox braces do exactly as the title would suggest.
The brace helps improve the shift making it more direct with increased feel. It has also been noticed that they provide chassis stiffening which results in a more positive handling chassis with increased steering feel and response. There is also a slight improvement in front end grip.
The braces come in kit form. It comprises of a three piece aluminium brace which has been CNC machined, a high tensile rubber/steel anti vibration block, gearbox mounting plate and the appropriate bolts (stainless steel where possible).
Fitting will take even an amateur around 30-45 minutes to fit. For the low outlay and ease of fitting this is a must have item for any high power B5 S4/RS4 even on a standard car you will notice an improvement.
ESP Engineering Billet Steel Gear Knobs.
These items have been designed primarily to improve the change on a car equipped with a short shifter kit, that’s not to say they will not improve a std shifter.
They improve the shift by subtly changing the weighting of the gearlever. This helps reduce the “notchyâ€
6speed front re-size.jpg (34.05 KiB) Viewed 3203 times
RS4 side RE-Size.jpg (35.12 KiB) Viewed 3201 times
RS4 RE-SIZE.jpg (34.58 KiB) Viewed 3203 times
Last edited by espengineering on Thu Apr 10, 2008 7:47 pm, edited 1 time in total.
Kylie Withall
Esp Engineering Ltd
esp.engineering@talktalkbusiness.net
espengineering
Post by espengineering » Thu Apr 10, 2008 7:33 pm
more pics
audi motorsport right re-size.jpg (35.65 KiB) Viewed 3201 times
audi motorsport front re-size.jpg (34.64 KiB) Viewed 3201 times
6speed left re-size.jpg (35.42 KiB) Viewed 3201 times
Kylie Withall
Esp Engineering Ltd
espengineering
Post by espengineering » Thu Apr 10, 2008 7:36 pm
and more
gearbox brace kit left re-size.jpg (36.45 KiB) Viewed 3204 times
rs4 side right re-size.jpg (35.46 KiB) Viewed 3201 times
S4 side right re-size.jpg (35.5 KiB) Viewed 3204 times
Kylie Withall
Esp Engineering Ltd
espengineering
Post by espengineering » Thu Apr 10, 2008 7:39 pm
more
gearbox brace oblique.jpg (36.36 KiB) Viewed 3201 times
gearbox brace kit right kit re-size.jpg (38.03 KiB) Viewed 3204 times
gearbox brace close up re-size.jpg (35.13 KiB) Viewed 3201 times
Kylie Withall
Esp Engineering Ltd
espengineering
Post by espengineering » Thu Apr 10, 2008 7:40 pm
Last pics.
gearbox brace zoom re-size.jpg (37.45 KiB) Viewed 3202 times
gearbox brace right rear.jpg (32.67 KiB) Viewed 3201 times
Kylie Withall
Esp Engineering Ltd
espengineering
Post by espengineering » Thu Apr 10, 2008 7:44 pm
two more
S4 front re-size.jpg (34.26 KiB) Viewed 3202 times
audi gear profile (re-size).jpg (34.58 KiB) Viewed 3202 times
Kylie Withall
Esp Engineering Ltd
andream88
Post by andream88 » Thu Apr 10, 2008 7:45 pm
Is it the "PVD Ti (black) coated Gear knob" the one pictured above??
Thank you ;)
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
espengineering
Post by espengineering » Thu Apr 10, 2008 7:50 pm
yep thats the coated ones.
there is a new pic above with the two side by side. Standard uncoated stainless next to the plated one.
regards.
Kylie Withall
Esp Engineering Ltd
espengineering
Post by espengineering » Tue Apr 15, 2008 3:41 pm
Ok so we have had alot of interest in the products if people wouldnt mind leaving feedback once they have received there items that would be great! :rocker:
Kylie Withall
Esp Engineering Ltd
MarkB
Post by MarkB » Tue Apr 15, 2008 5:10 pm
You might want to be @ Brunters on the 17th when we are all there :)
Mark
espengineering
Post by espengineering » Tue Apr 15, 2008 6:31 pm
Yep we will be there :wink:
Kylie Withall
Esp Engineering Ltd
ZKNY
Post by ZKNY » Mon Apr 21, 2008 7:21 am
kudos to you for the new items, designs, etc. especially on the DTS bar!
but just an FYI... metal knobs are... well, they conduct heat... so they get too cold n too hot all the time. too cold in the winter... too hot if left in direct sunlight. doyouknowwhaimean? but kudos again! where can i get more info like prices, pics, etc? keep up the good work, and thanks in advance.
espengineering
Post by espengineering » Mon Apr 21, 2008 7:42 am
hello,
What info would you like?
Most of the information needed is in the blurb,
regards
Kylie Withall
Esp Engineering Ltd
loomx
Post by loomx » Tue Apr 22, 2008 6:39 pm
Is the DTS pretty much exactly the same as the AWE one, will it be the same strength?
quattrokid1
Post by quattrokid1 » Tue Apr 22, 2008 6:57 pm
10 quid to post a knob!!
I do like the RS4 billed one I must admit....
be in touch:)
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro :):)
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD :( :(
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
Users browsing this forum: No registered users and 200 guests
