Only from pictures, but from what I can see a 993 (unless the tt was different) had a leading caliper where as it is now in a trailing position.Corey wrote:99% of all multi piston calipers have different sized pistons so the pad wear is even.GrahamS4 wrote:Interesting thread. Do the 4 pot Porsche 993 brakes have different size pistons?
It sounds like there is a quick method to check orientation? Is it which ends the bleed nipple is?
It is not nipple dependent on whether the small piston has the lead, it is whether the caliper (in its original fitment) is a trailing or leading caliper.
Are there any further visual check that can be done without removing the caliper?
ECS.
