Key Programming
Key Programming
I have just bouoght a used spare from Topbear on here as i lost my spare. I need to programme it. I done a search but cant make out whether this can be done by myself or this does have to be a trip to the stealers. Does anyone know what i have to do?
- Top Gear
RE: Key Programming
Search again!
You can code the remote central locking but not the immobiliser. That has to be done by a dealer.
RE: Key Programming
Moved to VAG-COM forum from B5 S4
I've just bought a gadget called Vag-Tacho from Ebay..... it works a treat to read the immobiliser code and programme keys! And what's more it was cheap... £28 delivered! Highly recommended......
When I say read the immobiliser code I mean you can read it and use the code to adapt new ECU's as well.. No more having to visit the stealers!
Here's the link! http://cgi.ebay.com/ebaymotors/VAG-Tach ... 0212666656
Are you saying it will do all thats needed to add a new key to the car. Immobilser adaption normally needs contact with the database in Germany to work.Mikey-S wrote:I've just bought a gadget called Vag-Tacho from Ebay..... it works a treat to read the immobiliser code and programme keys! And what's more it was cheap... £28 delivered! Highly recommended......
Mark
As I understand it, VAG-Tacho extracts the SKC which is then used with VAG-COM to code new keys to the immobiliser.MarkB wrote:Are you saying it will do all thats needed to add a new key to the car. Immobilser adaption normally needs contact with the database in Germany to work.Mikey-S wrote:I've just bought a gadget called Vag-Tacho from Ebay..... it works a treat to read the immobiliser code and programme keys! And what's more it was cheap... £28 delivered! Highly recommended......
VAG-COM can't read the SKC, VAG-Tacho is needed (or a trip to the dealer's to allow them to do it).
Steve, You'll need to buy a new blade from eBay and get a locksmith to cut the key for your ignition and door lock.stevieyid wrote:I just looked at the keys and although they have identical keys and look identical the actual key seems to be cut different. Do i have to get another bit cut for it? I just checked the key bit they both have HAA written on them, but the new (second hand) one has a w on the side of it.
I might get one of those. There is some coding I'd like to do on the cluster of our Golf too. Was that the seller you bought from Mikey?
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
The first one I bought wasn't from this seller, and it was faulty. After sending that back I bought this one and it works as described. One word of warning though... if any of you guys have Vag-Com you will see that the plug is just like a VAG plug, ie very slim. This one is a cheaper plug, and although it's a very tight fit it does plug in to the very small Audi plug surrounds. It works, but I keep thinking that I should have bought one with a Vag style plug. I have returned the first plug to the seller from Ebay and I'm awaiting his reply, at this point I won't mention any names because he seems to be a decent guy to work with, but I will let you know if he should be avoided. Mike.
So what do you enter for the date, WSC and importer numbers?
http://www.ross-tech.com/vag-com/tour/pin-skc.html
Mark
Good question! That's one for Ross Tech to answer. I'm not sure how that would work, but with Vag-Tacho you don't need any of the WSC, date or dealer codes. When using Vag com to code a key, the SKC is calculated using a combination of the date and the supplied codes. Vag Tacho reads the actual SKC code. Plus all of the B5 cars can be done using the 4 digit login, not the 7digit.
Users browsing this forum: No registered users and 20 guests
