Help.. K&N vs Pipercross vs BMC
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Mikey-S
Post by Mikey-S » Mon Mar 31, 2008 3:45 pm
Any advice as to which is the best filter? I'm only looking at around 350bhp, but want to buy the best, and the prices of these panel filters vary so much, ie K&N £45, Pipercross £18, BMC £40.....
kies4
RE: Help.. K&N vs Pipercross vs BMC
Post by kies4 » Mon Mar 31, 2008 4:03 pm
I run well over 400bhp with standard paper filter
S4 Crazy Horse. Ringsticker & MRC black magic.
Mikey-S
Post by Mikey-S » Mon Mar 31, 2008 4:11 pm
But what would you run with a low restriction panel filter? I bet you would see an increase in HP, if only slight. Gotta be a good £/hp ratio.
S4TAN
Post by S4TAN » Mon Mar 31, 2008 4:13 pm
I'm currently running a BMC panel - previous to that I ran an ITG foam ...
Deus ex machina
Mikey-S
Post by Mikey-S » Mon Mar 31, 2008 4:17 pm
S4TAN... just out of interest, where's your video clip from?
S4TAN
Post by S4TAN » Mon Mar 31, 2008 4:26 pm
HELL! :twisted:
Deus ex machina
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Mar 31, 2008 4:51 pm
Did run A K & N panel without any oil before I fitted the ITG Cone
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
kies4
Post by kies4 » Mon Mar 31, 2008 4:59 pm
not needed with <400 double check with a tuner and save yourself some dosh. I did have a K&N fitted but went back to standard on advice. If you go for one, get the ITG or the BMC the K&N oils can confuse the MAF
Blue_Thunder
Post by Blue_Thunder » Mon Mar 31, 2008 5:23 pm
Mikey, we'll meet up one night this week and i'll show you how restrictive the paper filter is on a K04'd S4
:twisted:
spen
Post by spen » Mon Mar 31, 2008 5:40 pm
I run a K&N cone @ 500 bhp. I am a minority of one. Everyone hates it but the rolling road number was ok, and the oils haven't caused any damage after 18 months use - I still get the vagcom max of 364g/s airflow. If I was to do it again I'd get an ITG foam as they are supposed to be quieter.
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
kies4
Re: RE: Help.. K&N vs Pipercross vs BMC
Post by kies4 » Mon Mar 31, 2008 5:55 pm
Blue_Thunder wrote:Mikey, we'll meet up one night this week and i'll show you how restrictive the paper filter is on a K04'd S4
:twisted:
show off !!! good to see your on the road
Blue_Thunder
Post by Blue_Thunder » Mon Mar 31, 2008 6:12 pm
:twisted:
Got to enjoy it whilst it lasts... :wink:
MCB
Post by MCB » Mon Mar 31, 2008 6:42 pm
To answer your Q I do not think you need to change from stock filter, IMHO the air box is a very good design and the air filter has a large surface area.
To date I have not seen undisputed dyno evidence that an aftermarket filter will provide you with power gains, although stand to be corrected.
S4B5 Avant
S4TAN
RE: Re: RE: Help.. K&N vs Pipercross vs BMC
Post by S4TAN » Mon Mar 31, 2008 6:44 pm
Just out of interest for all the detractors out there ...... a little while ago Doug did some tests with various panel filters (if I remember correctly they were ITG, K&N, BMC, OEM paper). The tests were conducted on one car, back to back, and the MAF figures were measured .....
Have a guess which filter showed to flow more air than the others .... (by quite a few g/s)
(clue: it wasn't the f*cking paper one!)
Deus ex machina
kies4
Post by kies4 » Mon Mar 31, 2008 6:49 pm
BMC panel ? :)
