BREMBO BRAKES
MarkB
Re: RE: BREMBO BRAKES
Post by MarkB » Sun Mar 30, 2008 8:45 pm
jimbo1234567 wrote:ive just measured the disc and its a piddley 350mm???????????????????? if someone was going to do a brake upgrade why make the disc smaller it doesnt make sense to me pad wise ive chucked the pagid blacks that were on it and am now going to use up the pagid yellows that came with the car. before long i can see myself taking it all off in favour of a b7 setup
There's been much talk about the 6 piston caliper/pad design being better than the separate pad 8 piston design though I must agree the larger disc does sound better...
Mark
bobbler
RE: Re: RE: BREMBO BRAKES
Post by bobbler » Mon Mar 31, 2008 9:50 am
Piddley 350mm? I thought the originals where smaller than that on the S4?
In fact, I am sure they are around 320mm on the standards up front?
352 is what you get on the ECS stage 4 setup
360 on the B5 RS4 IIRC.
363 on the B7 ?
All have more or less the same calliper design as you have already I think and I don't believe there is a lot of difference in the performance as you are talking about gnats hair difference in the disc size, especially when its 3mm on the B7 to the B5 - though there may be other differences in the disc design than just the size (someone with more insight than me may be able to chime in here?)
I would personally just get your current brakes working properly before you completely kick them into touch LOL or maybe compare to someone elses with similar setup?
EDIT:
Sorry just realised you are talking about a B5 RS4 that you have not an S4
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
MarkB
Post by MarkB » Mon Mar 31, 2008 10:02 am
B7 dia. is 365mm
Mark
S4
Post by S4 » Mon Mar 31, 2008 9:54 pm
can you tell me what discs you are running please? I take it they are a 350x32, but do you know what brand/model they are from?
Thank you
Darren
jimbo1234567
Post by jimbo1234567 » Tue Apr 01, 2008 5:37 pm
i have no idea ,they came on the car but il try and get hold of deane to find out
Corey
Post by Corey » Tue Apr 01, 2008 5:41 pm
Just put up a picture of the disc, that usually helps identify things
Corey
jimbo1234567
Post by jimbo1234567 » Tue Apr 01, 2008 5:46 pm
will do later this week , they look oem but turned down on a laithe
S4
Post by S4 » Wed Apr 02, 2008 12:02 am
OEM RS4? I know that loads of the Porsche disc`s are 350X32, maybe it is a Turned down OEM. Its so hard to find a 350X32 or near with the right offset without paying mega...... unless anyone knows better.
Darren
Corey
Post by Corey » Wed Apr 02, 2008 9:01 am
Wouldn't be a Porsche disc as the hub spigot and PCD is incorrect, there is a disc off the VW Touareg (has the same caliper as above) that is the correct size but again the PCD and hub spigot are different.
If it is a turned down OE then there must be one hell of a pad overhang as removing 15mm from the diameter (7.5mm radially) would reduce the area for the pad to sweep.
Corey
Nige_RS4
Post by Nige_RS4 » Wed Apr 02, 2008 9:24 am
Deans front discs were OEM RS4.
I had to out and check my calipers were on the right way last night!
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
MarkB
Post by MarkB » Wed Apr 02, 2008 9:31 am
The standard RS4 pad is very deep. The Porsche pad must be longer and narrower.
Mark
MarkB
Re: RE: Re: RE: BREMBO BRAKES
Post by MarkB » Wed Apr 02, 2008 9:33 am
bobbler wrote:Piddley 350mm? I thought the originals where smaller than that on the S4?
363 on the B7 ?
EDIT:
bobbler, could you measure the pad width of the cayenne calipers please? Effectively the the swept width of the disc.
Mark
bobbler
Post by bobbler » Wed Apr 02, 2008 11:48 am
Hi mate, which bit do you mean exactly? Disk width, caliper width or the brake pad itself?
s4woody
RE: Re: RE: Re: RE: BREMBO BRAKES
Post by s4woody » Wed Apr 02, 2008 12:01 pm
there are 2 type of pad sizes that fit the cayenne caliper..the ECS set up use the smaller of the 2..i know cos i had to get new pads and had to take the old pad as a ref...
GARTH ROAD MOT CENTRE LTD
020 83353032
MarkB
Post by MarkB » Wed Apr 02, 2008 12:18 pm
Dimension A and also the same on the pad. Thanks
Mark
Users browsing this forum: No registered users and 10 guests
