Some Great New Mods
Some Great New Mods
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
RE: Some Great New Mods
"Engine Oil Bypass Kit"
"Modern synthetic oil is very expensive - so why run the risk of getting it dirty by running it through your motor block? KaleCoAuto bypass kit comes with everything you need to run the oil around your motor block where it will do more good. Oil runs cooler, and as a result, there may be horsepower gains!"
Dave.
White MK2 Golf.. Slightly modified
Imagine if they were for real "why stop at cross drilled discs, now we have cros drilled brake lines... almost immediatly your hot brake fluid will be met with cold air"
Dave.
Blue_Thunder
- Top Gear
Nice find Graham
I've just ordered a bottle of their Engine Scrub - only $9.99
"Is the inside of your motor dirty? Most likely! Some people will tell you the only way to clean your motor is to tear it down and rebuild it. This is no good!!! KaleCoAuto internals cleaner is a special combination of iron, graphite, and copper shrapnel of assorted sizes that work to sand and polish the inside of your motor! Add 2oz per quart of oil in your car. New engine clean shrapnel should be used at every oil change! Bottle includes pouring mechanism. Comes in 16oz packages. Do not injest. Contact a physician immediately if injested, do not induce vomiting."
Clive
Users browsing this forum: No registered users and 46 guests
