leaks
2.7 V6 30v biturbo - 380 bhp
K2
leaks
Post by K2 » Fri Mar 28, 2008 12:13 pm
My RS has sprung a leek!!
Water is collecting in the rear offside footwell.
Got in the car for the first time in four weeks to find about 20mm of water.
Removed what i could see with many sponges, and the stuff kept re-appearing when driving, particularly when accelerating,... at one point it sounded like i had a small sea in the back of the car.
Throughout the day i stopped many times to soak up the water, and am now left with a car that smells like wet socks!!!!
Any one had a similar problem?
I'm assuming that a seal has split somewhere which is allowing water to get into the cill, and then into the car.
kies4
RE: leaks
Post by kies4 » Fri Mar 28, 2008 12:39 pm
I got this steamy window problem most likely leaves and debris in the bulkhead blocking the the drain points. clear it out and see how u get on.
may be not just re-read, the rear foot well, sorry no idea.
S4 Crazy Horse. Ringsticker & MRC black magic.
Virdee Autos
Trader (Expired)
RE: leaks
Post by Virdee Autos » Fri Mar 28, 2008 8:38 pm
Check the bulkhead drain plugs for starters.
One is easily visible, other one is harder, and the battery/battery tray has to be removed to access
Virdee Autos ~ 07950-526592
K2
RE: leaks
Post by K2 » Fri Mar 28, 2008 9:17 pm
I will give it a go.
Its just really wierd to be be collecting in the rear footwell!!
quattrokid1
RE: leaks
Post by quattrokid1 » Fri Mar 28, 2008 10:36 pm
I had this in my UrS4.... dry now without me doing anything (apart from dry it out) hasnt returned since... at a complete loss how the water got there!!
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro :):)
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD :( :(
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
Golich
RE: leaks
Post by Golich » Sat Mar 29, 2008 5:50 pm
Is the front passenger well damp? It might not be immediately obvious if the water is running backwards depending on how your car is parked.
The B5 A4 and A6 are known for letting water in around the base of the pollen filter when leaves and dirt gather around the bulkhead area. If this is the cause then I am guessing that when you accelerate you are perhaps forcing the water rearward.
Does your car have a sunroof? One of the other known leaks is the drains for the sunroof. These have been known to fill the rear quarter panels where the 6CD unit resides.
PS neither of these are difficult to fix. However, if you let water into the front passenger well appart from the damp smell. There are a number of ECUs under the front seat which control central locking interior lights etc which can be flooded = EXPENSIVE!
R5YUG
RE: leaks
Post by R5YUG » Sun Mar 30, 2008 5:33 pm
I had this problem a few months back, the drain plugs were full of acorns and leaves, causing water to fill up in the bulkhead / skuttle and over into the phlem chamber (where the pollen filter is) and into the heater pipes. (The lowest point pushes the water into the drivers side rear vents under the seat.
Remove all the plastic cowling, take the battery out and it's tray and vac all the leaves and debris out, also worthwhile using an airline down the drain holes to make sure they are clear. I also replaced the pollen filter whilst I was there and re-sealed everything with silicone just to be safe!
HTH Guy
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
Virdee Autos
Trader (Expired)
RE: leaks
Post by Virdee Autos » Sun Mar 30, 2008 5:45 pm
Forgot to mention that when you clean those rubber grommets out, it's best to remove them, and you'll see like a flower shape at the bottom of it.
Due to this, it clogs up. So best to cut the bottom of it, so you still have the rubber grommet part, and put it back.
I guess if you don't do this, it will only be a matter of time before it blocks up again!
This is what I did, and no problems at all.
K2
RE: leaks
Post by K2 » Sun Mar 30, 2008 8:15 pm
Thanks very much indeed.
Presently having just cleard the garage out, the car in now parked under cover and drying out.
Thought that this was the priortiy before trying to find the leak....
Was very concerned to find that there are a load of rather inportant electrics
under the seat,..... however, nothing seems to have gone tits up yet!
Will have a look at both the bulk head drains, and the sunroof.
From what R5YUG has experienced, my problem seems to be exactly the same.
Cheers :thumb: :thumb:
Simon.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 150 guests
