Just bought a new pc. Can't use my old usb modem, all the layout is different, it's just bloody annoying! It's now sat next to my old trusty XP system.
It's p*ssing me off!
I'm puzzled jeff - why does it make a difference if the 'interior' interface on your router is USB or Ethernet?* They're both LAN side ports, and the firewall policy acts on traffic ingressing on the WAN port by default (the cable/xDSL side) ...You really shouldn't be using a USB Modem ( I assume that you mean a DSL modem). It is the quickest way for your machine to be compromised going. The simplest thing to do is to get a standard ADSL Router with an Ethernet interface and connect the PC to the Router.
Don't know who supplied the PC to you, but perhaps go back to them and insist that they supply you with a copy of XP, FOC, as your other hardware peripherals don't work with Vista, otherwise you will have to return the PC.mikeyquattro wrote:Cheers TopBear. Just bought it today, preloaded with Vista Premium. I feel like wiping the HD and starting again!
I must go with the times and embrace new technology!
Vista SP1 Overview http://technet2.microsoft.com/WindowsVi ... d1033.mspxjeffw wrote:Vista is a good product that takes getting used to....give it a chance and upgrade it to SP1 when it is available.
I'm sure the SP1 beta I'm running said it would tell me when SP1 was GA... Thanks MS!!!TopBear wrote:Vista SP1 Overview http://technet2.microsoft.com/WindowsVi ... d1033.mspxjeffw wrote:Vista is a good product that takes getting used to....give it a chance and upgrade it to SP1 when it is available.
32bit Vista SP1 http://www.microsoft.com/downloads/deta ... layLang=en
64bit Vista SP1 http://www.microsoft.com/downloads/deta ... layLang=en
Dunno, I never installed the SP beta, however I'm sure I've read in the previous propaganda, ....err I mean Microsoft literature, that it's going to be drip fed to the general public during April via Windows Update as an 'Important Update', so you should see the 'wee yellow shield' popup in your taskbar soonPhilT wrote:I'm sure the SP1 beta I'm running said it would tell me when SP1 was GA... Thanks MS!!!TopBear wrote:Vista SP1 Overview http://technet2.microsoft.com/WindowsVi ... d1033.mspxjeffw wrote:Vista is a good product that takes getting used to....give it a chance and upgrade it to SP1 when it is available.
I kinda like Vista, and I say that having recently been through the which OS quandry. I wouldn't touch a Mac with yours, and linux took an age to setup and then delivered way under what Windows 3.11 "for Groupies" delivered 40 million years ago. Don't get me wrong.... each to their own, and linux works great on this server (Isn't bogomips a great measurement unit!!), and a Mac is great if you have an image crisis.
I'd say if you have a new system and have the sense to fill it full of RAM (= performance) then Vista is the only choice. XP is OK if the system is sub 3 GB RAM.
