Have a problem with Vibration on the back of my car
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
S4
Re: RE: Re: RE: Have a problem with Vibration on the back of
Post by S4 » Sun Mar 23, 2008 2:56 pm
BRETTCOLLINS wrote:Yes am thinking Rear hubs or bearings...
I would not think that both sides would be gone... usally just 1 side will brake down before the other.
Darren
buzzard
RE: Re: RE: Have a problem with Vibration on the back of my
Post by buzzard » Sun Mar 23, 2008 3:22 pm
hard launching can damage or even bend and twist half shaft/drive shafts
not so easy to diagnose but all that torque of a modded motor can put a serious strain on standard gear
S4 B5 long gone
S4 B8 Stage 2
BRETTCOLLINS
Post by BRETTCOLLINS » Sun Mar 23, 2008 5:16 pm
Swopped the wheels front to back and it has made no difference. the wheels do spin freely. At a loss now....
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
boxerdogted
Post by boxerdogted » Sun Mar 23, 2008 5:29 pm
Possible prop shaft. Center bearing worn or missaligned shaft.
Does it vibrate without braking ?.
2001 RS4 Misano Red
rolskii
Post by rolskii » Sun Mar 23, 2008 5:56 pm
hows the condition of rear bushes(lower-outer + upper outer) ...? condition of rears shocks ...
could be a drive shaft worn in excess that its getting a bit gyroscopic effect and/or inner diff. bearings from stubs ..?
how are yr diff/subframe mounts ..? looking past the obvious now....
happy dayz .... party ....
quattronutter
Post by quattronutter » Sun Mar 23, 2008 6:08 pm
get the car up with all 4 wheels free to rotate,try driving/braking with someone observing to see if anything becomes obvious,had similar troubles in the past with different cars
grizz
Post by grizz » Sun Mar 23, 2008 6:28 pm
Try a brake pipe clamp on one of the rear flexi pipes ,then on a quiet road at slow speed brake and see if you still have a judder ,then try it on the other one .
Unit 20
0151 3366888
BRETTCOLLINS
Post by BRETTCOLLINS » Sun Mar 23, 2008 10:58 pm
boxerdogted wrote:Possible prop shaft. Center bearing worn or missaligned shaft.
Only vibrates when braking, there is no vibration under hard acceleration, cruising speed or turning.
MING BLUE AUDI S4
Car is on Lock down
rolskii
Re: RE: Have a problem with Vibration on the back of my car
Post by rolskii » Sun Mar 23, 2008 11:40 pm
rolskii wrote: do the pads pass the inner edge of the disc ...?
do the pads overhang the centre of the floating disc ..? ..... enabling the pad to grab the underside edge of the disc ...?
do the pads sit in the carriers too deeply and extend pass the inner edge of the braking area ...?
BRETTCOLLINS
Post by BRETTCOLLINS » Mon Mar 24, 2008 10:04 am
will check this today. but as i said. don't think that it has anything to do with the brakes. because after changing all rear calipers, pads, discs and hoses. the problem i still there.
going to try clamping each hose on the rear later, to see if i can work out which side is the problem.. (good idea grizz) thanks
MING BLUE AUDI S4
Car is on Lock down
Blue_Thunder
Post by Blue_Thunder » Wed Apr 09, 2008 7:49 pm
Did you get anywhere with this Brett?
BRETTCOLLINS
Post by BRETTCOLLINS » Thu Apr 10, 2008 8:12 am
have all the bits to fit (very large box), just haven't had the time yet. set of rear hubs, new rear wheel bearing, All top and bottom rear arms, Full powerflex bush kit, 034 motorsport Engine, Gearbox and rear Diff mounts.
MING BLUE AUDI S4
Car is on Lock down
Blue_Thunder
Post by Blue_Thunder » Thu Apr 10, 2008 10:47 am
Ah, so wasn't a quick fix then?
BRETTCOLLINS
Post by BRETTCOLLINS » Thu Apr 10, 2008 4:49 pm
Don't know what is the problem, Could me a couple of things. So just fitting everything at once and help it goes away.. LOL
MING BLUE AUDI S4
Car is on Lock down
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Apr 23, 2008 9:51 am
update on this problem. once we took the rear hubs and arms off the car, we saw that the lower bush that sits in the rear hubs were in very bad condition. Ps: theses bushes don't come in the poly bush kit. so off to audi to get a set....
MING BLUE AUDI S4
Car is on Lock down
Users browsing this forum: No registered users and 107 guests
