Who's fitted RS4 B5 rear brakes to an S4.
BRETTCOLLINS
- 5th Gear
1. Are the calipers the same as the S4 units?
2. Can you use the standard S4 handle brake cable?
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
RE: Who
answers:
1) Depends... there are 3 types of r/calipers on s4... 1x solid discs & 2x vented -(was some ferral rogue set-up just after the solids were faded out, most have later vented .. i believe..?)
The solid calipers are no good so bin em, later vented may be okay.. maybe earlier too ..?
2) Yes you can use the original h/brake cables ....
drift back the hard plastic cable locators on the lower rear wishbones -pull the extra inch of cable back to the rear of car,
connect up to the situated rear calipers,
the plate that is held on the back of the calipers with a t30 fastener that locates the h/brake cable, this can be moved around slightly to accomodate the missing 10mm on the cable ....
it will all come clear when doing it ... but make sure you release the slack first as the cables go through the lower rear wishbones
happy dayz .... party ....
BRETTCOLLINS
- 5th Gear
RE: Who
Thank you. Am going to change them this weekend coming. will let you know.
My car is a 1998 car. But had already upgraded the rears to the vented units. Now I have a complete set of RS4 units. Calipers, Brackets, Hoses, Discs and backing discs.
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
BRETTCOLLINS
- 5th Gear
RE: Who
I have them, so will See
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Re: RE: Who
no need for apologies - already answered ... read the posts...Keihin wrote:Sorry for slight off topic, but I have worn solids and wonder how to upgrade to newer vented. Is this just a matter of buying new disks and pads? Are newer calipers the same?
It must be uncomfortable to have worn solids ... perhaps more spice is needed ... that will sort out the venting issue at same time ...
RE: Re: RE: Who
BOOM BOOM! Quality "bungles-finger" based humour there Roller!It must be uncomfortable to have worn solids ... perhaps more spice is needed ... that will sort out the venting issue at same time ...
Deus ex machina
BRETTCOLLINS
- 5th Gear
RE: Re: RE: Who
Once changed to RS4 on my car. Will put the vented kit up for sale.. Discs calipers and brackets..
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
BRETTCOLLINS
- 5th Gear
RE: Re: RE: Who
Is there a brake bleeding order on audi S4.s
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
RE: Re: RE: Who
I've got em on the back, sorted braking right out, used to get the back tring to overtake me with rs6 fronts and solid prefacelift rears.
Bleeding order, not sure, I usually have to suffer the misses getting up/down commands wrong, getting in a mood and waiting for a pal to come over. I but I guess your not taking about that order.
S4 Crazy Horse. Ringsticker & MRC black magic.
BRETTCOLLINS
- 5th Gear
RE: Re: RE: Who
Thanks But no, Anyway, my other half won't even go into the garage to get the car out, Let alone help me work on it...
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
RE: Re: RE: Who
normally the furthest away from the master cylinder 1st then work towards the closest being the last 1 to bleed...
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
BRETTCOLLINS
- 5th Gear
RE: Re: RE: Who
thanks swoody...
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
