pissed off
RS4 suspension I thought was 20mm lower?? So this should settle, but that far sounds a bit much. May not quite get the height at the back, but the weight diff between avant and saloon is like full tank vs empty tank of juice.
4-point or 4 post? The latter means the car can sit on full ramps though also lifted through extra jacks if need be.S4TAN wrote:everything was done and tightened on the 4-point lift (car was in the air)
2 posters have jacking point arms (albeit 2 per side hence 4-point) which suspend the wheels all the time.....
imolas4uk wrote:all the bolts that fasten through bushes should be tightened whilst the suspension is in a loaded state (weight of the vehicle on the wheels) so as not to preload the bush and cause premature failiure.this applies to all vehicles not just audi s4`s
Take a look at the front lower rear arms, they have a locating shoulder on the subframe to b*tt up against too.... to get that flat you have to rotate the middle bush upwards(or arm...)...... upwardly ......
You can tighten bushes/arms up to chassis in this state .... if its all apart.... fit it in as a proper job on rebuild ......
i doubt it will lower yr car though ...
I think it will be stamped or identified if its GMBH gear ...
happy dayz .... party ....
Users browsing this forum: No registered users and 114 guests
