Cam belt change
biggingermuff
Cam belt change
Just wondering what the general rule on cam belt intervalls are? Last done 2004 at 40K now mileage at 60K but coming up for a 4 year gap. Also anyone have an opinion on using the stealers for service Vs independants?
RE: Cam belt change
Specialists all the way mate!
Cam belt SHOULD be done every 40K IIRC; recommend that should be done anyway
HTH
MB
HTH
MB
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Current: A C6 Audi
Previous: A B5 Audi
neckarsulm
RE: Cam belt change
I wouldn't use a dealership as they don't see these engines much anymore so wont know there way around and also they don't replace as many bits as the specialists but charge about the same - some don't change the water pump - my old S4 had to go back 20k miles later (100k) for a water pump!
biggingermuff
neckarsulm
VW and Audi have just dropped the interval between cambelt changes e.g from 80k to 60k on 1.8T and brought in a maximum age regardless of mileage which I believe is 4 years - so now you have to disregard what the schedule says in the service book in most cases.
A nice move by VW so the the dealer workshops can rake in more cash - another reason to use a specialist
- Virdee Autos
- Trader (Expired)
Then again the 1.8T engines are notorious for belts letting go before 60k and 5years
So this is probably why they have dropped the interval
Virdee Autos ~ 07950-526592
neckarsulm
That was just an example, they have also done it with TDIs which always seem to make the interval - I have seen original belts at 90k when change is due at 60!Then again the 1.8T engines are notorious for belts letting go before 60k and 5years
- mikeyquattro
- Top Gear
- Virdee Autos
- Trader (Expired)
Bottom line for me is that I'd rather do it sooner than the interval. That might be my thinking, but hey thats me!
As soon as I bought my RS, thats the first thing I did, even though the last change was fully documented, and this change was not due yet
neckarsulm
4 years/40k sounds OK doesn't it or would you do it sooner than that?Bottom line for me is that I'd rather do it sooner than the interval. That might be my thinking, but hey thats me!
- Virdee Autos
- Trader (Expired)
I suppose it sounds ok, but I did mine for peace of mind, and knowing that it has now been done, with all the necessary parts, i.e. water pump, thermostat, etc
