Automatic Door locking on drive off ????? Worked for a week
skiwi
Post by skiwi » Thu Mar 13, 2008 8:25 pm
these are my notes from various sources and trial and error:
Coding:
+1 Boot Opening via Remote
+2 Confirmation Anti-Theft Warning System (Blink)
+4 Safety Central Locking
+8 Activate Anti-Theft Warning System (Interior Monitor)
+16 Automatic Boot Unlocking @5 km/hr
+32 Automatic Locking @15 km/hr
+64 Window Up/Down w/Remote
+128 Right Hand Drive (RHD)
+256 Avant Lighting Control?
+512 Confirmation Close via Remote (1x Blink)
+1024 Confirmation Remote closing (Horn)
+2048 Door-/ window regulator logic (operate 10 min with no door open)
+4096 Confirmation Unlock Blink (2x Blink)
+8192 No Safe-Function
+16384 Remote Central Locking: mechnical
Notes:
1 To remove all ACK flashes, turn off bits 2 and 10
2 Safety Central Locking uses a 2-press unlock 1st: Drivers door (using RHD indicator, bit 8), then all doors
3 Trunk unlocking function is incorrectly described in Bentley as a Locking function: Trun Bit 5 on to auto unlock @5km/hr
WeaselRS6saloon
Post by WeaselRS6saloon » Thu Mar 20, 2008 8:44 pm
Hi Guys,
well Audi fixed it, and better still my first claim with warranty direct has covered the cost ! Whilst car was in they found a problem with one of the parking sensors which they are also going to fix under the warranty, only been with Warranty Direct since mid Feb 08 so cant complain.
Anyhow Audi diagnosed the auto doorlocking fault as a problem with O/S/F door lock; part no. A402 837 016.
So far it has worked since Tuesday so I will see how long it lasts for,
cheers
Kev
WeaselRS6saloon
Post by WeaselRS6saloon » Tue Mar 25, 2008 8:22 pm
It broke again today ! :cry:
marmite
Post by marmite » Wed Mar 26, 2008 3:03 pm
You are going to need a new control unit buddy
03 RS6 Saloon Daytona Grey | Milltek | RS6+ Wheels | RS6 Mats | Tesco Club Card Points
WeaselRS6saloon
Post by WeaselRS6saloon » Sat May 10, 2008 8:54 am
Hi Guys,
I am hoping that someone maybe able to help me.............
I have asked Audi main dealer to order me a new central locking control unit "module 35" with firmware 38 which is noted on here to be the solution, however I have spoke to the Audi master workshop Tech who has tried to order this for me as he completely agrees that this is the solution, but he is being told that he can not specify which firmware the control unit comes with, basically you get what you get, and the only way to check which firmware it has is to open the packaging and plug it into read it, but then because its been opened you will be charged for it even if its wrong !
So basically can anybody help with a part or id nr for the control unit module 35 with firmware 38 ?
Kev
GardinerG
Post by GardinerG » Sat May 10, 2008 12:41 pm
Kev,
I can't help you with the part number but I wondered how much is it going to cost to get this unit and to have it fitted?
CheeRS
Grant
WeaselRS6saloon
Post by WeaselRS6saloon » Sat May 10, 2008 2:03 pm
Hi Grant,
not sure yet,
warranty will pay for it ! (otherwise I wouldnt bother), I will let you know £ if I ever get to the bottom of it,
Rgds
Kev
MoRS6+
Post by MoRS6+ » Mon May 12, 2008 11:27 am
Just chiming in..
Isn't this a bit like changing an entire PC motherboard to upgrade the BIOS (firmware)? Surely the whole point is to be able to update the firmware without changing the control unit. If the firmware is updated and the problem still persists then that would then point to the hardware (control unit) - unless of course it either a) Costs the same to just change it anyway - or b) The firmware cannot be updated on it and so HAS to be changed. Or maybe a third reason is that more money can be had by them changing the unit? Who's to know if they replace the unit for a newer one, and then behind closed doors reflash the old one and then sell that one on? On that basis, then you could possibly ask to have it changed on an exchange basis. Does anyone truly know if the firmware CAN be updated without changing 'em and if so, would the labour to carry out that procedure be a false economy as opposed to just changing it?
GardinerG
Post by GardinerG » Mon May 12, 2008 3:26 pm
Someone important at Audi wrote:Our Audi Centres can request stock to be checked at our Parts Distribution Centre if a Customer or Technician wants to confirm that we are supplying the latest software/hardware version of ECU.
RRP for the module is £200+ according to HO :shock:
Users browsing this forum: Google Adsense [Bot] and 166 guests
