Help on Buying an Air Compressor
I am looking at buying a cheap Air Compressor, it will be using for impact wrench, tyre blowing, air blow gun for cleaning things and maybe some painting ...
I am trying to work out what I need, but for example, here are two models
Airmaster Air Compressor - Tiger 8/44 - £87
Airmaster Air Compressor - Tiger 8/35 - £141
Now, as far as I can see, the cheaper one is better!!!!???
But, will this be enough for my needs or is going to keep running out of air and take ages to charge back up again??
I don't want to spend a fortune, but don't want to buy something thats not good enough for the job ...
Any advice??
cheers
Rich
PS, edited to say this looks quite good, with all the tools with it ??? Wolf Sioux II Air Compressor Kit
Any advice??
cheers
Rich
RE: Help on Buying an Air Compressor
The cheap one looks like it will do all the more expensive on does. For spraying you'll be on the limit on any of the ones you've listed.
Mark
How about this one ...
Wolf Sioux 50L Air Compressor Kit
Looks the same, but bigger 50L tank as opposed to the other three? will this mean I am not so much on the limit??
I found that using a die grinder was one of the main tools that needs loads of air. Obviously because it's run for long periods of time. Sand blasting also uses loads of air
Most nut/bolt turning tools I've found are fine even with a small compressor. Air saws will also use a fair amount of air.
Mark
don't get led by the size of the tank.
the important figure is the air delivery (cfm), or cubic foot per minute. You will find that things like drills and grinders need upwards of 4cfm.
Fortunately all those you listed show as being 7cfm. If you look at the spray gun you will see it is listed as being 7cfm, which is why Mark says it is marginal. It should be fine for a panel, but not a whole car unless you want to stop every now and then
I'm guessing based on what mine does, but for the compressor to charge a 50 litre tank from empty will be 30 seconds or so, so even if you do have to stop its not for very long.
Too many toys, not enough time
- mikeyquattro
- Top Gear
I've just got one of these for the new workshop could be a bit OTT for u .
http://cgi.ebay.co.uk/abac-GENESIS-7-5K ... dZViewItem
Unit 20
0151 3366888
0151 3366888
- mikeyquattro
- Top Gear
grizz wrote:I've just got one of these for the new workshop could be a bit OTT for u .
Nice!!
Tomorrow is another day
