RS4 Engine Rebuild for big power using a Garrett Kit
valve guides are usually fitted by either heating up the cylinder head and freezing the guides then once in position allowed to cool together for a tight fit..
best left to a machine shop for a proper job..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
I like the JCS High-grip they are a variation of the jubilee clip, Genuine Jubilee is also good. JCS also do one called High-Torque its a stainless version, marine grade. I think the zinc coated ones are fine in most applications, stainless just looks good. this http://cgi.ebay.co.uk/Miniclamp-Hose-Cl ... 0223490306 is a really good selection of small clamps, really handy. I got these and they were really good for all the small pipes.
oetiker stepless, is the clips fitted to the cars as standard ( I have the pliers, if anyone needs them) I went to southend Audi, and they said they don't use them! they said we use this ( it was a jcs clip) hope this is helpful
Darren
Darren
ive just bought the same a you rick..my wurth guy couldn't match the price for the clips..and i cant be bothered to go to macces..
020 83353032
020 83353032
philipwalker
- 5th Gear
The single use ones are better as they do not have any sharp edges, bolt heads that the Jubilee type have. These type can rub on hoses etc leading to leaks and damage to components.
As Simon suggests Wurth, supply a box of single use hose clips. The box has most of the sizes you should need, the correct tool is needed to crimp them for the factory look.
Yes as I said in the post I have the tool, if anyone wants to borrow it.(Essex) yes the minclamps are sharpish, but if you keep them clear of other hoses, and turn them the right way they are fine. they are also nice and round, I have had mine a while. you will be well impressed by the neat little rack they come with.
Darren
Darren
Just found that Garrett do a Speed Sensor, which I think it a neat idea! Perfect for making sure they are not over spooling!
Does anyone know of any good data loggers? preferably something thats in its own unit with alarms, a bit like the Zeitonix unit that can be stand alone and pass the data out to a laptop for reference ...
As far as my build is going, still waiting on parts!! but hopefully most of the stuff should be with me next week, so time to get cracking ...
Users browsing this forum: No registered users and 210 guests
