Window Rattle/Sqeak....
tweek
Post by tweek » Sun Mar 09, 2008 8:07 pm
Hi All,
Bought another S4 last weekend (Silver B7 Avant 23k miles 05 plate), bizarre after my last experience but goes better than a Focus....
Still, I carefully checked the car during the test drive for this annoying window rattle and was not sure if I believed my ears (not present), now I've got the car its loud and clear as daylight. Can anyone provide any suggestions as to improve or fix this irritation.
I have tried to get the dealer(s) to fix this type of problem in the past with a 100% failure rate so any suggestions would be most welcome.
This car does not have the dodgy clutch :evil: , the baulking gearbox :evil: , dodgy paint :evil: but has the window rattle :x so this is an improvement.
Pete
Post by chunky79 » Mon Mar 10, 2008 7:49 am
Hi mate
When does the rattling happen, fully up, half way or fully down?
Dunc
tweek
Post by tweek » Mon Mar 10, 2008 8:30 pm
Hi Dunc,
The problem is present with the window fully up. Lowering it slightly does seem to improve matters.
Pete
Mockenrue
Post by Mockenrue » Tue Mar 11, 2008 5:48 pm
Hi Pete
Did THIS solution I suggested last time not help at all?
Sounds like a lovely car. Any pics?
John
tweek
Post by tweek » Tue Mar 11, 2008 9:30 pm
Hi John,
Yes, I did try that on my old one but with no success, the new one also suffers from wind noise so pulling the frame out slightly may make this worse. Have actually tried this one with no success, maybe not being brutal enough :) ....
One thing I did notice, when the door is closed fully, there is a little bit of seal (at the top of the metal door skin) that appears should be in contact with the B post cover panel. There is quite a gap present, looking further showed that the door may not actually be closed enough due to the striker plate being out of position. When I get some time I will adjust the striker plate and see if this improves matters.
Pete
tweek
Post by tweek » Tue Mar 11, 2008 9:33 pm
Ooppps,
Forgot the pic, so hopefully here goes.
Pete
New S4 Avant - Front.JPG (115.47 KiB) Viewed 586 times
Users browsing this forum: No registered users and 120 guests
