Things You Could Move or Remove!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
DavidT
Post by DavidT » Sat Mar 08, 2008 10:09 am
I was thinking about things you could move in the car or get rid of & the pros & cons of them.
Can we put together a decent list in a standard format?
? means guess!
Here is my go at a format:
Move/Remove:
Description:
Pros:
Cons:
Parts Required:
Cost Parts (h):
Cost Labour (h):
Some obvious ones I thought of are:
Move/Remove: Remove
Description: Air Con
Pros: 30 kg weight saving?,
Cons: no Air Con
Parts Required:
Cost Parts (h): ?
Cost Labour (h): 6h?
Move/Remove: Move
Description: Battery to spare wheel well
Pros: 10kg moved back & lowered - better weight distribution & lower C of G
Cons: ?
Parts Required:Removable battery box & cabling
Cost Parts (h): ?
Cost Labour (h):2h ?
bobbler
RE: Things You Could Move or Remove!
Post by bobbler » Sat Mar 08, 2008 1:16 pm
Move/Remove: Remove
Description: Spare Wheel
Pros: Weight Loss
Cons: No spare but replace with a AA card or can of tyre weld
Parts Required: nothing
Cost Parts (h): nothing
Cost Labour (h): 2 minutes
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
rolskii
Re: Things You Could Move or Remove!
Post by rolskii » Sat Mar 08, 2008 1:38 pm
DavidT wrote:I was thinking about things you could move in the car or get rid of & the pros & cons of them
not alot to move ... just remove i'd say
If you remove all interior then the battery move to the boot will take about 30mins .... :lol:
Take you a day to lighten everything else tho ..? :roll:
pro's: lighter & no passengers
con's: no radio & difficult to start after a rear shunt ...
"Need 4 Speed" ... eh ..? is the competition getting to you ..? :wink:
Ash~ wot u reckon ..? :lol:
happy dayz .... party ....
DavidT
RE: Re: Things You Could Move or Remove!
Post by DavidT » Sat Mar 08, 2008 11:59 pm
Erm, thanks for that Rolski :?
rolskii
Post by rolskii » Sun Mar 09, 2008 1:05 am
Cant see the point to move anything ... cars designed how it is .. unless yr going really radical ... 1/4 mile stripster or such ..?
everythings wedged in nicely... ok lose ac rad for big fmic etc .. wot else though ?..? :lol:
dummi
Post by dummi » Sun Mar 09, 2008 6:43 am
ac is more like 10kg max but it is all over the nose
clubsport
Post by clubsport » Sun Mar 09, 2008 12:58 pm
Move/Remove:
Description: Fold down rear seats
Pros: Lower centre of gravity, much improved 0-60 & handling
Cons: Not that comfortable for rear passengers
Parts Required: None
Cost Parts (h): Nil
Cost Labour (h): 30-40 seconds.
It seemed to make a difference on my car :D
S4TAN
Post by S4TAN » Sun Mar 09, 2008 1:56 pm
^ PMSL :lol:
Deus ex machina
dummi
Post by dummi » Sun Mar 09, 2008 2:45 pm
clubsport wrote:Move/Remove:
Cost Parts (h): Nil
haha what about pumping the tires up to 38psi
DavidT
Post by DavidT » Sun Mar 09, 2008 2:46 pm
What about N249 delete or F-hose delete?
S4
Post by S4 » Sun Mar 09, 2008 2:51 pm
fit ultraleggeras around 8.1kg standard 12.7kg x4 then x 2 for rotational weight saving about 34KG
Darren
spen
Post by spen » Sun Mar 09, 2008 3:34 pm
Move/Remove: back seats
Description: er, you remove the back seats
Pros: they weigh a lot. Less passengers screaming at you.
Cons: drone from exhaust might be louder.
Parts Required: a socket set
Cost Parts (h): 0
Cost Labour (h): 1
Move/Remove: engine covers
Description: Remove all the plastic crap on top of the engine.
Pros: you can get to your engine now.
Cons: None whatsoever. The covers are totally pointless.
Parts Required: screwdriver or a twenty pence piece
Cost Parts (h): 0
Cost Labour (h): 0.1
Move/Remove: Horns
Description: Move the horns, the audible type that is
Pros: You can now fit a bigger oil cooler where the SMIC used to be
Cons: none.
Parts Required: bracket and some bolts
Cost Parts (h): 5
Cost Labour (h): 0.5
Move/Remove: undertray
Description: put the engine undertray in the bin
Pros: 5 to 10 degrees lower oil in the sump temp
Cons: engine gets splashed by puddles if you hit water
Parts Required: none
Cost Parts (h): 0
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
s4woody
Post by s4woody » Sun Mar 09, 2008 4:53 pm
Cost Parts (h): 0
spen your cost for parts is wrong..surely it,ll cost you atleast 20p if you aint got a screw driver
GARTH ROAD MOT CENTRE LTD
020 83353032
rolskii
Post by rolskii » Sun Mar 09, 2008 6:14 pm
dummi wrote:haha what about pumping the tires up to 38psi
Well actually that will increase the static weight .... aint that right jules ... :lol:
S4TAN
Post by S4TAN » Sun Mar 09, 2008 7:05 pm
It sure is mate .... also increase the rotational weight too ... :biggrin2:
Move/Remove: Remove
Description: Remove dead hooker from trunk
Pros: Less weight, less chance of being arrested, less flies buzzing round car
Parts Required: Bin bags
Cost Parts: £1.29 for a pack of 20 bags
Cost Labour: £0.00
:biggrin3:
Deus ex machina
