The Blue Thunder Diaries - Yet more Disappointment
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Blue_Thunder
Post by Blue_Thunder » Sat Mar 08, 2008 7:24 pm
Warning! - This post is rated 7 on the 'Rant-o-matic' scale
:rant:
A couple of months after finally getting the car 'sorted' (forgetting the turbo oil return pipe leak, coolant leak from the lower radiator pipe on the drivers side, etc.), I was finally preparing to put it on the rollers.
Took it up to Scotland last weekend and it was performing very well following a much needed 4 wheel alignment... until the bendy pipe blew off the bottom of my pass side turbo.
Had to nurse it round so many miles of lovely roads as best I could until a Kwik-Fit of all places sorted me out.
Paranoid as ever, I took the car over to Grizz today to get a healthcheck done before going on the rollers (and to check that my home install of my new boost gauge hadn't ruined everything). I was happy to learn it was all fine. Even managed to check the boost gauge against the pressure tester when Grizz did it, and was happy to see that it's spot on. Also checked lambda trims and no fault codes came up on Vagcom.
So, to the 'fun' bit. Met some S4 owners keen for a spin in a K04'd S4, so I was more than happy to oblige. After three spirited runs we got back to Awesome GTI and noticed smoke from under the bonnet. Fanf**kingtastic, I'd sprung a much more severe coolant leak, this time on the opposite side of the radiator.
Mentioned it to the guys just before it went on the rollers, they said it was nothing and wouldn't cause any issues (although they were very keen to make sure i'd signed the disclaimer first!).
So on it went. My arse was twitching like never before.
The 3 runs themself were actually quite uneventful, however I did smell burning, and immediately suspected the clutch. Naa... clutch is fine. The f**king exhaust has melted my rear bumper! Before and after pics to follow...
Once the run was over, checked the coolant level which had dropped by about half an inch. Filled it up before I drove the 30-40 odd miles home, then needed to add a litre when I got back. Boooo!
Had a rather disappointing 302.19bhp/379.85ft-lbs at the wheels. Was expecting more. Foolishly didn't take a photo of the plot when it was up on the computer (I was more worried about checking how much coolant was leaking from the engine bay). I'll have to post it when I can scan it.
Doesn't look right to me when comparing against plots from other K04'd S4's.
Torque shoots up until 3k rpms, then drops uniformly from there on downto 200ft-lbs.
Power also looks strange as rises fairly normally to 5k rpms, then dips down up to 6k and finally rises slightly upto 7k. Peak power on all three runs was at max rpms, I would have expected this a bit lower down the rev band?
Got home, ran Vagcom again and it's thrown a code:
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
Overboosting? If so, any ideas why?
Wasn't too impressed with Awesome TBH. Car was on and off within about 10 minutes, figures quoted were only at the wheels, no use of lambdas and the RR operators didn't even bother to explain what was going on.
I'll be using Dyno Demon next time.
:rant:
Blue_Thunder
RE: The Blue Thunder Diaries - Yet more Disappointment
Post by Blue_Thunder » Sat Mar 08, 2008 7:39 pm
Ladies and gentlemen... I give you the before and after photos of the 'Meltek' exhaust!
:evil:
jimbo1234567
Post by jimbo1234567 » Sat Mar 08, 2008 8:01 pm
sorry to hear about all this bad luck scott , were you cursed at birth or has it come on later in life? :thumbsdown:
Blue_Thunder
Post by Blue_Thunder » Sat Mar 08, 2008 8:12 pm
It's not me... it's the car!
GrahamS4
Post by GrahamS4 » Sat Mar 08, 2008 8:13 pm
OMG!
That pic is scary!
On and off the rollers in 10 minutes isn't a bad thing, nor is power @ the wheels, although I do personally prefer a dynodynamics so maybe Dyno Demon is the way to go.
I guess with that fault code you were not running correct boost hence your result. Photograph the printed plot and post it.
rolskii
Post by rolskii » Sat Mar 08, 2008 8:17 pm
wot a fvkking b*mmer dude .... at least that black section on the b*mper is replaceabubble .....
did you clear yr codes after kwik fit sorted you ..? if so u got a leak then i'd say ..... :thumbsdown:
happy dayz .... party ....
Blue_Thunder
Re: RE: The Blue Thunder Diaries - Yet more Disappointment
Post by Blue_Thunder » Sat Mar 08, 2008 8:28 pm
GrahamS4 wrote:Photograph the printed plot and post it.
What a dumbass I am, good thinking Graham. Just a minute...
Blue_Thunder
RE: Re: RE: The Blue Thunder Diaries - Yet more Disappointme
Post by Blue_Thunder » Sat Mar 08, 2008 8:31 pm
Blue_Thunder
Post by Blue_Thunder » Sat Mar 08, 2008 8:34 pm
I did clear the codes earlier in the week after Kwik-Fit had refitted the pipe.
Checked my long term fuel trims when I got back today and all of them were between -4 and -6. Boost gauge was still reading a healthy 19psi at full boost when I gave it a quick squirt on the way home. Also pressure tested it this morning, so pretty sure it couldn't have sprung a small leak in that time.
S4TAN
Post by S4TAN » Sat Mar 08, 2008 8:55 pm
Oh Scott dude ... you are surely the unluckiest S4 owner EVER! Condolonces on this long running saga of misfortune .... you should write a book!
Did they give you a calculated crank HP figure?
Deus ex machina
confusionhunter
Post by confusionhunter » Sat Mar 08, 2008 8:55 pm
With 4wd transmission losses, doesn't 300 WBHP translate to 400 flywheel??
Mark.
S4TAN
Post by S4TAN » Sat Mar 08, 2008 8:56 pm
Don't think it's a fixed 25% loss ....
Deus ex machina
jeffw
Post by jeffw » Sat Mar 08, 2008 8:58 pm
Not sure of the spec of the car but if it's K04, exhaust, injectors then 300 at the wheels is about right
confusionhunter
Post by confusionhunter » Sat Mar 08, 2008 9:02 pm
true but wasnt there a post that a B7 RS4 had only just over 300 on the rollers at the wheels? What was the conclusion of that?
Mark.
S4TAN
Post by S4TAN » Sat Mar 08, 2008 9:04 pm
It wasn't making 414 at the crank ...! None of them seem to even come close to the official figure when dyno'd....
... remember all the posts about it in the B7 RS4 forum ...? :lol:
Deus ex machina
