2871R's should be good for 350bhp each IMHO, be really interesting to see how your build comes on mate.
Cheers,
Andiroo
That is the plan, but I think I will need to run it on stock RS4 cams until I can afford a custom set ... be good to benchmark the two anyways ...dummi wrote:you going to get some custom cams?
Cheers mate, I have S4 Pauter rods, says on the box as well "Without EDM", which, I think is an oil hole? anyway, think I need the S4 shells for these....musty1 wrote:I would replace the shells as you have it open already also use sputter shells for the conrods in layman terms use the rs4 upper shell for both bottom and top. good luck rich seems you going to get there before I do let me know if you need anything
Around 40k ...g60bv wrote:how may miles had that engine done. interesting to see the bore wear. etc
