got bored today...
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
quattronutter
Post by quattronutter » Wed Mar 05, 2008 10:33 am
i just tipped some parafin in one end nothing comes out any of the other 3 outlets,whatever it is its blocked solid,it was only 100 euros though,il see if i can get it chopped open see whats in there,must have spent 8 hours trying to start it,sump was half full of fuel...
spen
Post by spen » Wed Mar 05, 2008 9:33 pm
in a way that's really lucky. Think what'd have happened if it, whatever it is, had moved and broken up en route down intake :shock:
good job you didn't tow it ;) I did that once after a build and the engine ate the airfilter. Totally ate it. :(
is it run it yet? 8)
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
quattronutter
Post by quattronutter » Wed Mar 05, 2008 9:53 pm
had it running with the intercoolers bypassed,need to find another fmic now,glad i didnt tow it!!its running nicely now after sorting about 10 throttle faults logged,the oil i drained out was like water with all the fuel mixed in after all the cranking,just need to re assemble pedal box and sort a fmic and its ready for the road,il run it in gently with no boost for 1000 miles then think about altering the map to suit the k04 hybrids and water/methanol,i hope the rs4 clutch will handle it,i dont think it will last too long with the extra 200bhp of nos though...
spen
Post by spen » Wed Mar 05, 2008 10:13 pm
aahaaaah, your rs4 clutch will bite the dust! . :bigwave: to your clutch. 500 ftlbs and that's about it, at least the way I launch?
quattronutter
Post by quattronutter » Fri Mar 07, 2008 12:41 am
checked the raceware head studs torque now its been run up to temp several times and most of the studs required a good 1/8th of a turn to reach the correct torque again,so worth checking if you run with studs
quattronutter
Post by quattronutter » Sun Mar 09, 2008 7:55 pm
new intercooler fitted and all is well,water/methanol kit ready to fit as well as the nitrous,il get it run in before thinking about these though
quattronutter
Post by quattronutter » Sun Mar 09, 2008 7:57 pm
just need to fit my special number plate,note the lower bumper grilles fitted
spen
Post by spen » Sun Mar 09, 2008 8:26 pm
:drink: party time!
S4TAN
Post by S4TAN » Sun Mar 09, 2008 8:29 pm
Good job on getting the lower grilles to fit over the FMIC pipes dude .... what's the secret?
Deus ex machina
rolskii
Post by rolskii » Sun Mar 09, 2008 8:32 pm
S4TAN wrote:Good job on getting the lower grilles to fit over the FMIC pipes dude .... what's the secret?
Time I reckon ... looking good ..... :D
happy dayz .... party ....
quattronutter
Post by quattronutter » Sun Mar 09, 2008 10:16 pm
a sharp hacksaw is the key
jimbo1234567
Post by jimbo1234567 » Sun Mar 09, 2008 11:17 pm
where is your fmic conversion from. i like the way the pipework sits. :nogarors4:
quattronutter
Post by quattronutter » Sun Mar 09, 2008 11:29 pm
its my own homebrewed fmic,pipework made up from 2in stainless also has a shrouding which you cant see in the pics,stops any air escaping round the sides of the intercooler,every little bit helps...
quattronutter
Post by quattronutter » Sat Mar 15, 2008 12:12 am
its alive again 8) just need to rack up a few miles before some map tweaking,then its time for the rs4 panels to go on
Picture 016.jpg (65.86 KiB) Viewed 687 times
quattronutter
Post by quattronutter » Sat Mar 15, 2008 12:14 am
another...
Picture 018.jpg (65.56 KiB) Viewed 692 times
