got bored today...
quattronutter
quattronutter
quattronutter
quattronutter
have the cam sprockets been off the cam's..there is no key way so its easy to get em out of alignment..but then saying that if the valves aint hitting the pistons you should be ok..and im confident you know what your doing..
where abouts are you based..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
quattronutter
timing is good i checked everything 3 times over,cams lined up and bottom pulley lined up on tdc mark,g28 engine speed sensor is getting a reading too if i check with vagcom measuring block 3,as i turn the engine over
quattronutter
i didnt rebuild the heads as the were in top condition,that and the fact im putting 2.4s and bigger turbos on next time round,im in northamptons4woody wrote:have the cam sprockets been off the cam's..there is no key way so its easy to get em out of alignment..but then saying that if the valves aint hitting the pistons you should be ok..and im confident you know what your doing..
quattronutter
i found the reason for non starting,the large fmic i bought from germany has a major blockage no airflow through it at all
,with the intercooler bypassed it started up after a struggle,so be carefull with those cheaper german fmics!!!im going to cut it open see whats inside it tomorrow,if im lucky it might be stuffed full of money
Blue_Thunder
- Top Gear
jesus holy hell . thats unbelieveable. those unit cant be flow tsested very well then. -bought in germany . made in china.
we fought em on the beaches, we fought over land and sea. and they bugger us with dodgy automotive goods 60 years on. barstards.
haha
haha
MRC TUNED 480BHP . -SOLD 1.9TDI AVANT 215HP. HYDBRID TURBO. SMOKING
Users browsing this forum: Google [Bot] and 85 guests
