Urgent help needed regarding HALDEX controller....Vagcom
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
B7B7B7
Post by B7B7B7 » Sun Mar 02, 2008 8:10 pm
Address 01: Engine Labels: 8N0-906-018.LBL
Part No: 8N0 906 018 J
Component: 1.8L R4/5VT G 0004
Coding: 10710
Shop #: WSC 80179
WAUZZZ8LX21002834 AUZ7Z0A1887012
2 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-00 - -
Readiness: 0000 0000
Address 22: AWD Labels: 02D-900-554.LBL
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 56: Radio Labels: None
Part No: 8L0 035 195 H
Component: symphony II NP2 0151
Coding: 00201
Shop #: WSC 00000
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
44-10 - Short Circuit - Intermittent
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
Any 1 any ideas...... most importantly the haldex controll unit?????
GrahamS4
RE: Urgent help needed regarding HALDEX controller....Vagcom
Post by GrahamS4 » Sun Mar 02, 2008 8:39 pm
Brake light switches are common failures I believe. Cheap and easy to fix.
Popular issue on the MKIV Golf and the 4Mo guys gets the same Haldex errors as you.
Certainly worth trying it first. Don't be fooled by working brake lights, they are dual circuit.
S2tuner
Trader (Expired)
Post by S2tuner » Sun Mar 02, 2008 9:29 pm
I'd suggest having your car looked at, the engine side of things looks really bad.
Return to “DTC / VCDS”
