fitting a new wheel on Monday after the original was badly damaged.
can you swop over the pressure sensor and metal value or do you have to buy new from Audi?
Thanks in advance.
fitting a new wheel
fitting a new wheel
2007 RS4 Avant Phantom Black - Buckets - sat nav - SS+ - Privacy - 6CD - window blinds - carbon inlays - GSM prep - homelink - auto dimming mirror - pogo alert
2008 X5 3.0sd M-Sport
2006 535d M Sport Touring Silver Grey SOLD
RE: fitting a new wheel
Both should be fine as long as the valve was not damaged too. The sensor should certainly be OK.
Re: fitting a new wheel
No problem at all. If it does work afterwards it will be because it was damaged in the process of changing.hunty wrote:fitting a new wheel on Monday after the original was badly damaged.
Thanks in advance.
RE: Re: fitting a new wheel
thanks for that guys.
pippyrips wrote:No problem at all. If it does work afterwards it will be because it was damaged in the process of changing.hunty wrote:fitting a new wheel on Monday after the original was badly damaged.
Thanks in advance.
meant to say if it DOESN'T work!
Users browsing this forum: No registered users and 235 guests
