RNS-E into RS4 by Doug
Doug_S2
Trader (Expired)
RE: Re: RE: RNS-E into RS4 by Doug
Post by Doug_S2 » Fri Feb 22, 2008 9:50 pm
a pic - need to take a pic in better light
satnav fitted.JPG (80.37 KiB) Viewed 1856 times
http://www.MRCtuning.com
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Feb 22, 2008 10:12 pm
Looking good Doug!
I did it another way as per a guide which I found.
Basically move some pins around on the grey instrument cluster connector (IIRC) and then on the radio connector side.
Let me know if your still stuck and I'll dig out the guide.
Virdee Autos ~ 07950-526592
TDiAvant
Post by TDiAvant » Sat Feb 23, 2008 9:25 pm
The old RNS-D did not use can-bus from the instrument cluster, so you are going to have to tap into the infotainment can-bus wires in the cluster. I cannot remember which wire is can-high & can-low, but I can get you the information if your stuck
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat Feb 23, 2008 9:32 pm
It's either 5+6 or 12+13 or something like that.......
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat Feb 23, 2008 9:37 pm
i already have wires connected in both those positions i nthe instrument cluster - so is it a case of splicing into them? the guides i have seen have not already had those pins there
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat Feb 23, 2008 10:06 pm
Yeh if you wish you can splice into them, and then bring the wires down to the RNS-E, and connect them where appropriate on your adapter harness
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Feb 24, 2008 4:54 pm
another couple of pics without flash - it is hard to take a good picture of this!
MarkB
Post by MarkB » Sun Feb 24, 2008 5:13 pm
Looks great but I still say it needs the heater panel also.
I see you have a happy helper :D
Mark
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Feb 24, 2008 6:39 pm
he's happy - but a helper? not sure about that!
if you change the ashtray to the standard plastic from a a4 it would look more normal - getting the controal panal piano'd would be nice but too much £££££. i can live with what it is now - the heaters don't bother me.
DamoM
Post by DamoM » Tue Feb 26, 2008 4:15 pm
Looks good Doug. Did you get it working ok? I know we went through quite a bit to get it working on my RS4, but it was a long time ago now so have forgotten exactly what! Mine is only slightly modified to make it fit and it has the side gaps but to be honest is looks OEM and nobody has ever asked me if it was a retro-fit.
I bought the clock fix module too and also a unit to display boost pressure etc in the DIS.
I think that out of all of the sat nav systems in different cars that I have the RNS-E is the best, pariculalry with the latest firmware and the traffic warning working. The re-routing due to traffic is excellent.
The only problem that I couldn't ever sort properly was the speaker that the routing came out of. Despite changing the settings in VAGCOM the lady only every spoke out of the right rear speaker! It's ok actually cos that actually puts the voice in your right ear anyway! TBH, I turned the voice guidance off as the in dash DIS directions are excellent.
1995 (M) Noggie RS2. MD357 turbo and remap. tba bhp.
2000 (X) Noggie RS4. Miltek Cat back. No cats. B7 discs/RS6 calipers. ally flywheel, DUH FMIC, ceramic coated tubular manilfolds, large intake pipes, RS6 turbos, 3" downpipea, large injectors etc MRC remap, 592bhp, 535lbft
1990 (Q) 20vURQuattro. Being fitted with RS4 motor & 6 speeder,porsche brakes.
PetrolDave
Re: RE: Re: RE: RNS-E into RS4 by Doug
Post by PetrolDave » Tue Feb 26, 2008 4:54 pm
DamoM wrote:The only problem that I couldn't ever sort properly was the speaker that the routing came out of. Despite changing the settings in VAGCOM the lady only every spoke out of the right rear speaker!
That's a common side effect of the "VIM hack".
DamoM
Post by DamoM » Tue Feb 26, 2008 5:07 pm
so no way round it then...!!
PetrolDave
Post by PetrolDave » Tue Feb 26, 2008 8:28 pm
Have a read of the thread on www.navplus.us - there appears to be a way round it by going through several different versions of the SW upgrade...
R5YUG
RE: Re: RE: Re: RE: RNS-E into RS4 by Doug
Post by R5YUG » Thu Feb 28, 2008 12:03 am
Good progress.... out of interest what steering wheel is that you have installed Doug?
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Feb 28, 2008 2:20 pm
R32 mkiv wheel
Return to “Electrical”
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 51 guests
