Wheel/Suspension Setup
Julian, perhaps your spring is upside down ?
Did you compare the springs before you put them on to ensure they are the same height, as thats a big difference and the difference is not linear, so winding one down 10 mm will not drop the car 10mm that side if you know what I mean ?
Do they have part numbers to compare ?
When I adjusted mine, I took the coilovers off and measured them to match each other. They were about right when I dropped the car down.
Paz, makes sense in one way but its hard to get that exact compared to measuring to the ground ?
Dave - don't know how a spring could be on upside down ... the coilovers came ready built from Eibach; single piece units, nothing to build. Looked exactly the same in the box... and you can't put a coilover on upside down!
The coilys came as a full set with matching P/N's ... so don't think it's a mismatch ....
Went for a spin earlier, and endulged in some 'enthusiastic' cornering action ... they seem to be levelling out now so I'll see what the score is tomorrow...
I dunno ... fooking cars!
Deus ex machina
Soupie69uk
One of you guys should bung your arb on the softer setting to see how it handles. Not going to do any harm going by these people having cracked frames.
Then I will know how to fit mine when I eventually get them. Loots like I am going to have to heighten my coilovers as mine are about 60.7cm Front and 61.2cm at the rear. Not going to go too much higher though.
Re: RE: Re: RE: Re: RE: Re: Wheel/Suspension Setup
Did you get it sorted ...? your not suffereing the dreaded cracked sub frame are you dude ..?S4TAN wrote:Phew - thanks Dave!
So, answer me this then: my passenger side rear c/o spring perch is wound right down to near the end of the strut (the end nearest the ground), in fact about 2cm from the end... and my drivers side rear c/o spring perch is set higher, i.e. about 5cm from the end of the strut ..... yet my bloody car is 1cm lower at the rear on the drivers side than it is on the passenger side!
How is it after tweaks at MRC ..?
happy dayz .... party ....
Rick KerryZeroK66 wrote:Kies, have you got a contact number/web address for him.
Anyone else know of another company that supplies the rods as mentioned by Derdle? Sounds ideal for running a car low, but keeping geometry the same...
Ipswich Accident Repair Centre
36 Gloster Rd
Martlesham Heath,
Ipswich,
IP5 3RD
01473 624890
http://home2.btconnect.com/IARC/Racing.html
you'll find him willing to talk till the cows come home, a nice bloke
S4 Crazy Horse. Ringsticker & MRC black magic.
I have found the address and phone number for David Dyson, the guy behind Custom Performance Products who made the adjustable stuff on my car.
27836 Gerhart Lane
Tracy
California
95304 -8173
USA
Tel: 1-209-839-0695
Paul
27836 Gerhart Lane
Tracy
California
95304 -8173
USA
Tel: 1-209-839-0695
Paul
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin
If you dont "do it now" you never will.
Huge Grin
Thanks to everyone... information overload
My one tyre which went pop had my fit one of my rear tyres to the front and the car is MUCH more settled & feels a much nicer ride. Clearly my knackered tyres had something to do wtih it. While running the H&R setup as low as it was I could not get the alignment right. Since the PSS9s kit the alignment was 100% I was told.
Hopefully a set of nice light 18's with new tyres all round + a few tweaks as discussed in this thread so far will see the car transformed!!
Quite excited!
Quite excited!
Hi Guys, well the latest update as follows.
I have kept BBS CH wheels, but got for them in 18" x 8.5 with 225 tyres. Unfortunately even with the smaller rim and slimmer tyre the 18x8.5 225 are 2kg heavier than the 19x8 235. Anyway...
The car handled the bumps much better and gave overall a much more forgiving ride.
I had the ARBs set to the softer setting and the car is better again on bumpy roads and for normal driving. Unfortunately it has lost its sharpness on fast bends. First few corners gave me a fright as the car did not behave as I expected. It feels foreign to me!! Lets hope I get used to it.
Next I plan on raising the ride height as the camber cannot be set within tollerance at the height I am now (63cm) I will raise the car 2cm all round and see how if the alignment can be made then and come back with an update.
Cheers,
Cheers,
Users browsing this forum: Majestic-12 [Bot] and 43 guests
