************Product Update(ESP Engineering)***********
espengineering
Product update on the gear box brace bars, we assembled and fitted and tested on our own S4 so far so good, really responsive, really good feed back on it, easily fitted, good clearance over all well chuffed with it!Hopefully we have independant RS4 and S4 owners coming down this week for testing, wait for the feedback.
Gear knob update, we have a couple in the field being tested hope to be getting feedback on these soon, watch this space.
Looking at new products, possibly Billet lightweight fly wheels and Billet aux drive pullies, Thoughts and opinions please people
Thankyou
Kylie
Thankyou
Kylie
espengineering
RE: ************Product Update(ESP Engineering)***********
Also Work has been started on the short shifter kits trhere is a possibilty that these are going to be adjustable for individuality and prefered driving styles.
I thinking about flywheel options at the moment but don't want the gear noise that comes with it being too light.
Mark
espengineering
Not sure about that, i would imagine that is why they use dual mass fly wheels to soak up the vibration, hopefully the tuners will be able to answer that question, im not brainey enough!
Re: RE: ************Product Update(ESP Engineering)*********
I think the noise is caused by gear 'chatter' which the OEM flywheel damps out.MarkB wrote:I thinking about flywheel options at the moment but don't want the gear noise that comes with it being too light.
espengineering
RE: Re: RE: ************Product Update(ESP Engineering)*****
Also just been looking at some pictures of the engine and recently made some vernier cam pullies for a customer, would this be something any one else would be interested in?Tuners?
Re: RE: Re: RE: ************Product Update(ESP Engineering)*
espengineering wrote:Also just been looking at some pictures of the engine and recently made some vernier cam pullies for a customer, would this be something any one else would be interested in?Tuners?
You don't need adjustable pulleys as they are fully adjustable as standard .
Unit 20
0151 3366888
0151 3366888
- confusionhunter
RE: Re: RE: Re: RE: ************Product Update(ESP Engineeri
true but you dont get the accuracy of running them both at1 or 2 degrees advance or not.... plus although they are interferance fit I wouldnt dare
try setting the pullyes without the brace bar with means you cant really set them anything other than std.... where as with verniers you could run them both at sat 4 degrees advance after you set them up as std..... ?? that make sense?
Mark.
Re: ************Product Update(ESP Engineering)***********
Tip regarding the lightweight flywheel. You will be competing against companies that mass produce flywheels for many different vehicles who will be able to under cut your prices unless you cut corners in the development process or you are not in it to make a reasonable profit. I have seen B5 S4/RS4 lightweight flywheels on the internet for about £180.00. Food for thought. Go away and cost up a 12" diameter billet, a ring gear, steel face plate, input shaft bearing and the cost to balance the flywheel. Good luck if you go down this road, but I have been there and the UK market (in general) will not pay the prices for low volume high quality flywheels.espengineering wrote:Product update on the gear box brace bars, we assembled and fitted and tested on our own S4 so far so good, really responsive, really good feed back on it, easily fitted, good clearance over all well chuffed with it!Hopefully we have independant RS4 and S4 owners coming down this week for testing, wait for the feedback.
Thankyou
Kylie
RE: Re: ************Product Update(ESP Engineering)*********
I have one of yours Karl, its a lovely thing. Seemed a shame to install it !
espengineering
Thankyou
Kylie
Thanks for the heads up, we are just pricing up at the moment, we will keep trying it and see where we go! £180 is seriously cheap though god!
Thanks again
Thankyou
Kylie
Thanks again
BRETTCOLLINS
- 5th Gear
Support backets for rear sub frame may be a good thing to look at. As people keep breaking them with uprated ARB's..
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
espengineering
Yes we are looking at these as well, Liam is getting his Booby belly under the car this week and is going to see what he can do!
Just been down to see Liam so that he can test fit the DTS to a RS4. The stabiliser looks lovely as does the gear knobs, the DTS bolted straight on to my RS4 without modification....pukka job.
Certainly worth talking to Liam if you want a DTS or a gear knob....I'm going to have a black gear knob
whats the cost of the DTS? it has to be a fair bit lower than what can be had, as even paying cusoms there re some good deals?
any pics?
Darren
any pics?
Darren
Users browsing this forum: No registered users and 92 guests
