Wanted: Tool to remove valves and springs
viperbl
Post by viperbl » Sun Feb 24, 2008 8:35 pm
I need to get hold of the tool to remove and fit the intake and exhaust valves/springs on my rs4 and 2.4 heads ...
Does anyone have any that I can buy/borrow or know where I can get some??
Cheers,
Rich.
RS4 B5 Saloon8) with 750+ bhp :D
Doug_S2
Trader (Expired)
RE: Wanted: Tool to remove valves and springs
Post by Doug_S2 » Sun Feb 24, 2008 9:00 pm
halfords!
http://www.MRCtuning.com
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Feb 24, 2008 9:03 pm
on second thoughts - what are you doing with the heads? and are they new 2.4 heads?
viperbl
Post by viperbl » Sun Feb 24, 2008 9:26 pm
Plan is to use the 2.4 heads on the engine instead of the RS4 heads ... they are second hand, just trying to clean them up, get the valves/springs etc out, going to get stronger springs for them ... maybe a new cam if I can afford it ...
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Feb 24, 2008 10:01 pm
i would advise you to get the heads pressure tested and if you are doing that just send the heads off to a good machine shop to do all the work (pressure test, check guides, replace seals, check guides, recut the seats, and just check everything!) the last hing you wnat ot do is putit back together and a small thing means pulling hte engine again! You will need to use a machine shop for getting your crank balanced to your rods anyway.
viperbl
Re: RE: Wanted: Tool to remove valves and springs
Post by viperbl » Sun Feb 24, 2008 10:07 pm
I hear you, good advice Doug thanks ... I have a machine shop already sorted to do the balance, so I will see if they can also do the heads ...
Is it just a standard tool I need to remove the valves/springs etc then? at least I can get all the stuff out so I can get it cleaned up ... got a nice friend that said I can use his dishwasher to clean then :lol:
Doug_S2
Trader (Expired)
RE: Re: RE: Wanted: Tool to remove valves and springs
Post by Doug_S2 » Sun Feb 24, 2008 10:10 pm
A standard tool will work if you get the small adapter for the small intake valves with it.
s4woody
Post by s4woody » Sun Feb 24, 2008 10:56 pm
until you get the tool you can remove the valve springs by getting a socket that is the size of the spring caps..then using an extension on the socket place the socket over the spring and hit it with a hammer..the spring will compress quickly and release the collets..it will work and the spring wont fly up and smash you or anything..and no you wont damage anything..
GARTH ROAD MOT CENTRE LTD
020 83353032
viperbl
Post by viperbl » Mon Feb 25, 2008 11:09 am
Cheers Woody! I will be trying this tonight :)
DavidT
Post by DavidT » Mon Feb 25, 2008 11:50 am
Rich, can I move this to the Tuning & mod forum now ? contents seem more relevant for there.
viperbl
Re: RE: Re: RE: Wanted: Tool to remove valves and springs
Post by viperbl » Mon Feb 25, 2008 11:53 am
DavidT wrote:Rich, can I move this to the Tuning & mod forum now ? contents seem more relevant for there.
Yea, good idea ...
viperbl
RE: Re: RE: Re: RE: Wanted: Tool to remove valves and spring
Post by viperbl » Mon Feb 25, 2008 2:12 pm
Would something like this do for both the small and large valves on the engine ??
http://cgi.ebay.co.uk/NEW-Multi-Valve-S ... dZViewItem
S4
Post by S4 » Tue Feb 26, 2008 12:54 am
sykes pickervant do some nice ones.. you can get one with double ends.. big or small, Like Doug said.
Darren
viperbl
Post by viperbl » Tue Feb 26, 2008 9:59 am
Cheers guys, and the socket and hammer work to get them out :)
Users browsing this forum: No registered users and 61 guests
