beep, beep, beep... beep
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
tjd100
Post by tjd100 » Fri Feb 22, 2008 5:44 pm
No change on the DIS at all - i did wonder if it could be related to the cruise (haven't done anything to the lights) but the way I remember it was happening before I installed cruise. Still most likely explanation so far - as in chances are if theres something wrong with your car you were the cause of it...
I'll disconnect the cruise and see if that gets me anywhere.
Thanks for the suggestion
DavidT
Post by DavidT » Fri Feb 22, 2008 6:22 pm
Have a look around the Ross Tech Site : www.ross-tech.com & their WIKI site too: http://wiki.ross-tech.com
I can move this thread into the VAG-COM forum if you like, one of the Ross Tech folks will see it in there?
tjd100
Post by tjd100 » Fri Feb 22, 2008 8:31 pm
no change after cruise disconnect - also checked ross tech and came up blank.
bugger...
please move if you think useful, although car clear of all fault codes (running vag com on a genuine cable)
DavidT
Post by DavidT » Fri Feb 22, 2008 10:32 pm
Moved. Can't do any harm.
Sebastian
Post by Sebastian » Sat Feb 23, 2008 6:26 am
I read through this topic but couldn't find anything about real details.
Year? Make? Model? Mods? :)
Sebastian @ Ross-Tech.com
tjd100
Post by tjd100 » Sun Feb 24, 2008 12:09 am
1954 Chevrolet 3100, with airhorn.
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 65 guests
