phenolic spacers for the rs4?
2.7 V6 30v biturbo - 380 bhp
dummi
Post by dummi » Fri Feb 08, 2008 8:04 pm
they're available for s4 , are they for the rs4 engine? if not why not!
Doug_S2
Trader (Expired)
RE: phenolic spacers for the rs4?
Post by Doug_S2 » Fri Feb 08, 2008 9:53 pm
i got some here
http://www.MRCtuning.com
S4TAN
Post by S4TAN » Fri Feb 08, 2008 10:13 pm
i got some here
Yeah .... ya bugger!
Deus ex machina
dummi
Post by dummi » Fri Feb 08, 2008 10:28 pm
Doug you ahead of the game
S25MRS
Post by S25MRS » Sat Feb 09, 2008 9:43 am
Please excuse my ignorance.........'phenolic spacers..... :?:
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
S4TAN
Post by S4TAN » Sat Feb 09, 2008 11:42 am
Phenolic spacers are inserted between the inlet manifold and the heads - they insulate the IM from absorbing heat from the heads such that air passing through it isn't heated up - cooler air = more power. Additionally they extend the intake runner length and give better low-end torque. Manufacturers claim a 5-10hp power@crank increase, and a 10% drop in IAT's.
Deus ex machina
S25MRS
Post by S25MRS » Sat Feb 09, 2008 11:46 am
Ahhhh, I see - thanks..... 5-10% is a good increase for something relatively straightforward, surely. Any detrimental affects at all?
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
S4TAN
Post by S4TAN » Sat Feb 09, 2008 11:52 am
No, none AFAIK. They cost about £80 for a set (with gaskets and bolts included)
5-10hp is definitely a good power increase for £80! - and a 10% IAT reduction is well worthwhile.
Deus ex machina
S25MRS
Post by S25MRS » Sat Feb 09, 2008 12:14 pm
Sounds like a good idea to me - if I've got any money next time in Banbury, I'll speak to Doug about it
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
okkim
Post by okkim » Sat Feb 09, 2008 3:48 pm
Has anyone proven that those parts really work? The air flow is so massive and fast trough the IM, that in my opinion it will cool the IM by itself. Only thing when it could help is when the engine is hot and idling.
S4TAN
Post by S4TAN » Sat Feb 09, 2008 3:58 pm
I know what you're saying okkim - but I guess through the very act of cooling the IM the air flowing through it must pick up the heat (as logic dictates) before entering the cylinders ..... I think the phenolics are a 'Tesco' mod, but worth it (especially if you're combining it with changing the after-run pump as I am, because the IM has to come off anyway)
Deus ex machina
dummi
Post by dummi » Sat Feb 09, 2008 5:29 pm
small but valid difference, remember under compression there is a lot of heat, it all adds up in the course of the air going into the engine. its whether you want to or not really, not going to make a big difference
S4TAN
Post by S4TAN » Sat Feb 09, 2008 7:29 pm
Agreed - the air flowing through the IM will extract the heat from the manifold and that heat has to then go somewhere .... the cylinders! Surely better to have a nice cold IM for your air to flow through.
As you say, won't make a big difference, but every little helps ... and anything that lowers IATs is a GOOD thing.
Deus ex machina
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat Feb 09, 2008 7:51 pm
mapped a 500 bhp s4 and a 620 bhp rs4 one night - gave them lots of WOT runs and drove back to the shop sensibly, off boost, around 1 mile, Got out - touch the IM and the S4 was hot and the rs4 the same night - stone cold. s4 no phenolics, rs4 phenolics - good enough reason for me that they do something.
andream88
Post by andream88 » Sat Feb 23, 2008 8:44 pm
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
Users browsing this forum: Majestic-12 [Bot] and 155 guests
