Part Number help needed please. 2001.5 intake manifold
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
MarkB
Post by MarkB » Thu Feb 07, 2008 6:58 pm
This is excelent info. I'll take some similar pictures of the early type manifold so we can compare.
As far as I can see, this is only relevent to the B5 S4, would this thread be better in there?
I think it's worthy of linking from the B5 S4: Modifications sticky (so I've done it). Top work :thumbs:
Mark
tdiquattro
Post by tdiquattro » Thu Feb 07, 2008 7:22 pm
Thanks Mark mate, yep your right the S4 B5 forum would be better :-)
just to clarify to fit this manifold in place of the early S4 one you need to;
- move the N249 connection to the connector on the top in the pics,
- cut off and tap both fat connectors,
- block one with a threaded plug
- convert the second to 1/2" barb for the brake vacuum hose
- re-locate the EGT sensor modules
I think that's it, I haven't done it yet, but will post a how to when I have.
Nige'
2000 silver S4 Saloon
MarkB
Post by MarkB » Thu Feb 07, 2008 7:33 pm
I'll move it over then :)
One thing I'll add when I do mine is... I plan to replace my spider hose at the same time with the later version ( minus the f-pipe) so this might connect directly to the BC manifold.
Mark
tdiquattro
Post by tdiquattro » Thu Feb 07, 2008 8:21 pm
The RS4 / 2001.5 spider needs the "suction jet pump" assembly, the u shaped arrangement of valves and pipework........
9 and 10 connect to the fat connectors I chopped off of the back of the BC mani,
7 to the brake servo and 3 to the spider.
So you would need to build this as well from audi part numbers, I looked at it, but unless you can get one second hand it is prohibitively expensive. If you can get it you will have effectively built a late allroad mani and pipework setup. There are a couple of other small hose differences as well including the one to the N75.
Nige'
MarkB
Post by MarkB » Thu Feb 07, 2008 8:47 pm
Ah, more than I thought. I'll be looking closer at your plan then :D
Mark
MarkB
Post by MarkB » Tue Feb 19, 2008 4:28 pm
tdiquattro wrote: I tried to find straight 3/8"BSP to 1/2" barbs but no luck.
How about THESE?
Mark
tdiquattro
Post by tdiquattro » Tue Feb 19, 2008 6:15 pm
yep look great, should work well. (Mark! :D )
Nige'
