Flywheel weight
Flywheel weight
Anyone know what the standard flywheel weighs please?
RE: Flywheel weight
12.5 Kgs
http://www.MRCtuning.com
Re: RE: Flywheel weight
Thanks Doug.Doug_S2 wrote:12.5 Kgs
RE: Re: RE: Flywheel weight
And the lightened ones are around 6-7 kgs ?
Also, what do we think the gains are? I was told 20-30 ft/lbs of torque ?
BRETTCOLLINS
- 5th Gear
Do they all chatter? How refined do they get?
What are the gains typically?
What sort of cost are we talking?
What is the effort to fit and what sort of additional effort are we talking if you were already replacing the clutch?
Anyone had a lightweight flywheel on a K03 S4?
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
I have installed a few Fidanzas. The engine revs more easily, but I haven't noticed so big difference when driving (haven't done any logging, just normal driving). Of course it helps, when it's more than halve the weight of the original.
It doesn't give any more power or torque, it just "releases" it from the engine. (if you don't change the boost or timing, how could it anyway...?)
One Fidanza is now on eBay, 165£. Those are quite cheap, but those work ok!
Installation is quite easy when the clutch is out, but those bolts have to damn tight when installing. You just need some muscle
Having decided to go the K04 route I now have a slight obsession with lag and response so I am looking at reducing mass where possible, and within a budget that doesn't make me whince too much.
I have been looking at the 034motorsport steel flywheel that comes in at 15lbs. It's a couple of lbs heavier than the aluminium wheel but should suffer less chatter. However it does not work with an RS4 PP and would requires a Sachs or Spec alternative. We are talking about a grand landed cost
BRETTCOLLINS
- 5th Gear
Users browsing this forum: No registered users and 154 guests
