Show us your boost gauges !!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
AdamS4
RE: Re: RE: Heres how i did mine
Post by AdamS4 » Fri Feb 15, 2008 12:03 pm
Mmmmm, more options... LOL
S4, Shame its in BAR and not PSI
Richspec, Isn't your vac a bit low ??
bobbler
Post by bobbler » Fri Feb 15, 2008 3:34 pm
PLX looks interesting, and certainly a match for the dash as its a miniture display!
http://www.plxdevices.com/products/dm200obd/
Pricey though but may be worth considering if you wanted a few functions?
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
BRETTCOLLINS
Post by BRETTCOLLINS » Fri Feb 15, 2008 4:04 pm
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Richspec
Re: RE: Re: RE: Heres how i did mine
Post by Richspec » Fri Feb 15, 2008 5:51 pm
rikrose wrote:and masking tape.
LOL, its to stop the expensive carbon dash from getting scratched, it didn't!
'98 Imola Avant - at last! :)
Vag-Com/710N's/afterun mod
Richspec
Post by Richspec » Fri Feb 15, 2008 5:53 pm
AdamS4 wrote:Mmmmm, more options... LOL
Dunno, is it??
that pic may have been taken before i zeroed it, but i think thats 'there or thereabouts' for what it normally reads :?:
S4TAN
RE: Re: RE: Re: RE: Heres how i did mine
Post by S4TAN » Fri Feb 15, 2008 6:12 pm
Don't worry - it's not low Richspec. Your gauge measures in psi for both boost and vacuum. Other gauges use inHg for vac and psi for boost. Healthy car should read around 17-20 inHg vac which is the same as ~ neg 8-10 psi (yours looks to read ~-9 psi vac - so spot on)
Deus ex machina
Richspec
Post by Richspec » Fri Feb 15, 2008 7:30 pm
Thanks for that, with all the other things that need sorting i don't need anything else! :beerchug:
Blue_Thunder
Post by Blue_Thunder » Fri Feb 15, 2008 7:47 pm
AdamS4 wrote:Well, i'm not getting a reply from Omori and i've emailed Blitz to see if they do the MD mirror drive gauge in PSI rather than BAR.
There is NO WAY i'm playing £198 for a boost gauge.... AWE/Regal can fu*k right off.
I've spoken to AWE today and they've told me that Omori has ceased trading and they are sourcing some new gauges (probably why they were reduced). In addition, they also said they wouldn't ship to the UK because Regal had paid a load for the selling right. Shame they're so greedy!
Think I might go with the Blitz gauge. Would be nice to see one in the flesh to make sure it's not too big for a centre vent.
AdamS4
Re: RE: Re: RE: Re: RE: Heres how i did mine
Post by AdamS4 » Fri Feb 15, 2008 8:26 pm
S4TAN wrote:Don't worry - it's not low Richspec. Your gauge measures in psi for both boost and vacuum. Other gauges use inHg for vac and psi for boost. Healthy car should read around 17-20 inHg vac which is the same as ~ neg 8-10 psi (yours looks to read ~-9 psi vac - so spot on)
Ah thats why i thought it was low.... Sorry :oops:
That SPA gauge is top of the list so far !! :D :thumb:
g60bv
Post by g60bv » Fri Feb 15, 2008 9:39 pm
[quote
quote]
this looks sweet.
MRC TUNED 480BHP . -SOLD 1.9TDI AVANT 215HP. HYDBRID TURBO. SMOKING
saf
Post by saf » Sat Feb 16, 2008 1:04 am
g60bv wrote:[quote
quote]
this looks sweet.
Best Ive seen so far. Really impressed with that for what it can show you and the customization aspects can allow you to make it blend in well with the Audi.
Great find. Ill be ordering one as soon as I find its 100% compatible.
g60bv
Post by g60bv » Sat Feb 16, 2008 10:38 am
just what i thought. the only prob is having to run the lead from the vagcom socket to the dash. unless the socet could be moved to a more forward position. $400 plus delivery est $530 £270. gulp.
bobbler
Post by bobbler » Sat Feb 16, 2008 10:50 am
g60bv wrote:just what i thought. the only prob is having to run the lead from the vagcom socket to the dash. unless the socet could be moved to a more forward position. $400 plus delivery est $530 £270. gulp.
That is pretty good though really, when you consider Regal charge £188 for a AWE gauge which does one thing. Further gauges are also £100/$200 on their own.
I would look at maybe detaching the vag-com port from the rear ashtray and fixing it inside the tunnel. You could then run the cable easily enough for a stealth install that should be easy to undo should you need to.
AdamS4
Post by AdamS4 » Sat Feb 16, 2008 11:49 am
Then another ~£50 for import duty tax
TBH, its nice and handy having all that info there, like the SECS monitor but nicer... but how are you going to view it all while driving, the display looks rather small.
Vagcom can monitor all those.
ChipHazzard
Post by ChipHazzard » Sat Feb 16, 2008 11:58 am
that looks like a good gauge, and if it's programmable I'd guess it could be setup to read the maf as well.
Another option to relocating the obd port could be to install a second one in parallel giving the ability to site one near the gauge and leave the other in the rear ashtray, then all that would need to be done is unplug the gauge whilst using Vag-com on the port in the ashtray just something to consider and I may be completely wrong
my 2p's worth
Mike
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
