RS6 Turbos - Max Boost
2.7 V6 30v biturbo - 380 bhp
rs-mad
Post by rs-mad » Fri Feb 08, 2008 1:14 pm
Hi Guys,
Just wondering if anyone can tell me the max boost that they have found they can run with a pair of RS6 turbos (not hybrids) while maintaining efficency?
TIA
RS-MAD
okkim
RE: RS6 Turbos - Max Boost
Post by okkim » Fri Feb 08, 2008 1:56 pm
You should ask max mass airflow, because basically the boost doesn't mean anything. Then you can compare boost if the engine is totally same, and also the hot side of the turbo. Because the pressure comes from restriction, if the engine flows freely, you can't get boost at all, but the air mass is big.
rs-mad
Post by rs-mad » Wed Feb 13, 2008 6:55 am
Okkim - Thanks do you now the max mass airflow the turbos are good for?
okkim
Post by okkim » Wed Feb 13, 2008 9:52 am
No, sorry. You have to read the RS6 compressor map and calculate.
spen
Post by spen » Thu Feb 14, 2008 5:02 pm
From the RS6 turbo: K04-29 map whilst keeping the efficiency >70% or better
max pressure ratio: 2.7 @ 0.155 m3/s airflow by volume @ max shaft speed 167,000 rpm
ie max boost 25 psi
max flow rate: 0.175 m3/s airflow by volume @ pressure ratio 2.21 @ shaft speed 156,000 rpm
ie around 200 g/s (or 400 g/s for two , or even 510 bhp)
If you forget about the efficiency, run the compressors off the map, and deal with the heat, on my S4 heads / intake / exhaust combo the RS6 turbos could make 613.93 bhp assuming VE of my combo doesn't change from current (in reality it would).
It's all numbers and theory, and I could have got it wrong on my scrap of paper!. You're probably better off fitting them and measuring EGT, exhaust manifold pressure and intake temp. Stop when one of these gets too high.
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
flashyg
Post by flashyg » Fri Feb 15, 2008 12:05 am
I got 480 on the maf from memory!
Low egts,intakes and healthy timing. No water injection.
The turbos will go more but may not last or be as efficient.
Car did 518 bhp@TW with 1.9 P to 1.5 RL in 3rd.
Loving it, shreds rear tires in 3k too.
rs-mad
Re: RE: RS6 Turbos - Max Boost
Post by rs-mad » Fri Feb 15, 2008 10:50 am
flashyg wrote:I got 480 on the maf from memory!
What car do you have? 518hp is that Flywheel or Wheels?
Jarv
Post by Jarv » Fri Feb 15, 2008 11:16 am
'TW' = The Wheels.
Mike
Q7
Hutch
RE: Re: RE: RS6 Turbos - Max Boost
Post by Hutch » Fri Feb 15, 2008 4:13 pm
Dyno setting on shoot6F AND done in 3rd gear. Anyone would think you're trying to cheat the numbers G :wink:
Nice MAf reading :bowdown:
flashyg
Re: RE: Re: RE: RS6 Turbos - Max Boost
Post by flashyg » Fri Feb 15, 2008 11:52 pm
Hutch wrote:Dyno setting on shoot6F AND done in 3rd gear. Anyone would think you're trying to cheat the numbers G :wink:
But I'm not .You cheeky little minx. We all know shoot 44 gives bigger FW figures. I don't need em. :lol:
In fourth Ill have more Poower!
Who's got a big wheel power then :assflash: .That's all that matters no water injection either!!. Sorry just enjoying the moment.
Watch out a k16 car could be along any minute to get me, never the biggest fish...Satins child, Andy even, Stevey.DDave the list goes on.
Good luck to all.
G
quattronutter
Post by quattronutter » Fri Feb 15, 2008 11:56 pm
i have some k16s looming for next year 8)
flashyg
Post by flashyg » Sat Feb 16, 2008 1:15 am
Lucky boy. You'll love em.
Go on, go on as Mrs Doyle would say.
Hutch
Post by Hutch » Sat Feb 16, 2008 9:52 pm
Only joshing you bud, I'm just jealous!
I can see a fast and furious race coming up, lets just hope that yellow Elise from Spa isn't around!
grizz
Post by grizz » Sat Feb 16, 2008 9:58 pm
I can see a head to head with "hutch & flashyg " at rs246 live ..
Unit 20
0151 3366888
flashyg
Post by flashyg » Sun Feb 17, 2008 8:02 pm
What memories we have. That big moment an the medium shekane at the end of the straight. That was good fun. Supercharged fiberglass buckets are definitely quick. You did the right thing though. What fun.
Users browsing this forum: No registered users and 107 guests
