Carbon inlet manifolds....
tartan_rob
Post by tartan_rob » Wed Feb 13, 2008 11:35 am
Any interest in these?
Also thinking about designing and building a single piece intake pipe from the MAF into the turbo's...any interest?
Both for any S/RS model?
Am willing to put the time into development and mould making but only if the interest is sufficient.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Andiroo
RE: Carbon inlet manifolds....
Post by Andiroo » Wed Feb 13, 2008 11:40 am
Are you looking at a copy of oem intake manifold in carbon Rob, or something a bit tricker? :wink:
Cheers,
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
JonnyX
Post by JonnyX » Wed Feb 13, 2008 12:18 pm
I would think you would need a good unstanding of CFD to do this properly.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
tartan_rob
Post by tartan_rob » Wed Feb 13, 2008 2:43 pm
I am qualiifed in thermofluids and hydrodynamics so can have a good stab at this. As I'm going to be making the components myself, the costs to me are not so high, if it don't work I can re-tool and re-make without having to pay someone else to. That should keep my R&D costs down to a bare minimum.
2017 Kawasaki Z1000
2014 RS6
2014 S1
rikrose
Post by rikrose » Wed Feb 13, 2008 7:22 pm
Is it going to provide any reasonable gain, though? The propshafts I understand - inlet manifold.. not so. Can you explain how this would provide a reasonable benefit? Is there anything else you could think of that would benefit from being made form CF that would be likely to provide a better benefit?
Goodwood green RS4, previously owned by jeffw
AdamS4
Post by AdamS4 » Thu Feb 14, 2008 8:37 am
There must be some kind of gain as most race cars use CF inlet systems.... either for weight saving or keeping the air colder and more dense.
tartan_rob
Post by tartan_rob » Thu Feb 14, 2008 9:22 am
I think initially it is a weight saving exercise (and less heat soak for cooler/denser air) although if you are smart with the design of the moulds, you can get much better and more direct airflow. Its all about understanding the fluid dynamics. As for the increased gains....who knows. Time will tell. I would expect initially that the weight would be the immediate benefit coupled with better heat control. How much does a "normal" cast intake manifold weigh?
Initially I'd like to just create a copy that works to understand the pressures, then it is a pure R&D exercise to get the fluid dynamics right. I going to work with MRC if they will let me, to make a few parts and work with them on the development......
2017 Kawasaki Z1000
2014 RS6
2014 S1
spen
Post by spen » Thu Feb 14, 2008 8:48 pm
I'm interested, depending on cost.
Also fatter intake pipework down to the turbo inlet, if you want some ideas?!?
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Feb 14, 2008 9:36 pm
maybe we should do one of our dual throttle body inlet manifolds in CF - i'll talk to you about this next week rob.
http://www.MRCtuning.com
rikrose
Post by rikrose » Thu Feb 14, 2008 10:08 pm
Now it's been mentioned, I've been wanting to ask about that since you pointed out the second throttle body on your car. I've been resisting the urge to ask about it until you mentioned it in public.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Feb 14, 2008 10:13 pm
That has been on my car for a few months to test the software and hardware mods we need to run 2 throttle bodies on the standard ecu. I'll be running a dual throttle body manifold in the next few weeks. Would be nice to do it in carbon as well!
dummi
Post by dummi » Thu Feb 14, 2008 11:36 pm
flash git :P
tartan_rob
Re: RE: Carbon inlet manifolds....
Post by tartan_rob » Fri Feb 15, 2008 9:10 am
spen wrote:I'm interested, depending on cost.
Myself and Doug are looking at this next week.
RE Dual throttles, yes we should talk Doug.
2017 Kawasaki Z1000
2014 RS6
2014 S1
ZKNY
Post by ZKNY » Sat Feb 23, 2008 9:57 am
i want in! =D
g60bv
RE: Re: RE: Carbon inlet manifolds....
Post by g60bv » Sun Feb 24, 2008 9:36 pm
this all sounds -SWEET-
rob. keep me informed. also is it not pos to make the apr pipe in carbon. better than crappy ali cast. and probably the same price...
MRC TUNED 480BHP . -SOLD 1.9TDI AVANT 215HP. HYDBRID TURBO. SMOKING
Users browsing this forum: Google [Bot] and 92 guests
